Golf servo M50 conversion length of spacer?
EOS
Hi just finished my M50 conversion, but having a small issue with my brakes at the moment, what length did people make the spacer for the master when using the golf servo?
Toby_Unna
- Boost Junkie
trial and error mate.
needs to be just long enough to take out slack, but without pre-loading the master cylinder when you push it against the servo
get something easy to cut like a pencil, cut a section off and try it. keep shortening it until the master cylinder will just fit flush with the servo without the piston moving.
that make sense?
that make sense?
Toby_Unna
- Boost Junkie
er, edit, then when you have the right length re-make the spacer from an old bolt that fits snug in the hole in the master cylinder. don't use the bit of pencil lol
- Homo Hair
Toby_Unna wrote:er, edit, then when you have the right length re-make the spacer from an old bolt that fits snug in the hole in the master cylinder. don't use the bit of pencil lol
ed325i
If you use the mk1 golf servo it fits on without the need for the spacer.
ED
ED
Andy335Touring
I thought it was the Mk1 GTI that just bolts on ?ed325i wrote:If you use the mk1 golf servo it fits on without the need for the spacer.
ED
- Homo Hair
its a case of finding a mk1 being broken nowadays tho
a mk1 non gti one would be good for me..
ed325i
Sorry yes mk1 gti golf just bolts on. I think the non gti ones are smaller but should still bolt on??Andy335Touring wrote:I thought it was the Mk1 GTI that just bolts on ?ed325i wrote:If you use the mk1 golf servo it fits on without the need for the spacer.
ED
ED
ed325i
jmc330i
Yeah the Mk1 Gti servo fits without the spacer, but it does need the linkage at the back to be drilled out to accept the E30 linkage pin.
The Mk1 non-Gti servo will fit, but its to small for the E30 - the brakes on the Mk1 1.3 Golf were bad enough. Its not something Id want to use on an M50 converted E30
As has been mentioned, finding a Mk1 Gti servo isnt going to be easy now. I think they can still be bought new, but wont be cheap.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- Homo Hair
ive driven without the servo disconnected and could still lock the brakes, a small servo isnt really an issue for mejmc330i wrote:my pic is being used.
The Mk1 non-Gti servo will fit, but its to small for the E30 - the brakes on the Mk1 1.3 Golf were bad enough. Its not something Id want to use on an M50 converted E30![]()
just where the hell to find one
EOS
cheers guys, looks like i'll be going with some trail and error this weekend then
EOS
well im hoping with the Z3 rears and E36 front brakes i should be able to stopThe Mk1 non-Gti servo will fit, but its to small for the E30 - the brakes on the Mk1 1.3 Golf were bad enough. Its not something Id want to use on an M50 converted E30
Did feel pretty damn good going round the block. Maybe thats cause they were already half on
jmc330i
The brakes will be fine, they must work without the servo, but it all depends on hard you want to press on the brake pedal.
With the smaller servo, you will need to press harder.
(if Ive got that right
James
'91 325i Sport
'91 325i Sport
- Homo Hair
jmc330i wrote:The brakes will be fine, they must work without the servo, but it all depends on hard you want to press on the brake pedal.
(if Ive got that right)
yep thats right
stevetigger
I thought with a smaller servo you have more vacuum, therefore you would need to press the pedel less "Hard"
I went round the block with my "Small" servo and the brakes felt the same
alexbaby88
I bought a Golf GTi Mk I off German Ebay, but ended up using a E30 iX tandem servo instead when one turned up.jmc330i wrote:my pic is being used.
Would like to sell it as I have no use for it.
However I am in Malaysia. Please PM me if keen and I can find out postage costs to ship the thing to Blighty.
EOS
Shortened my spacer and all seems well at the moment, altho i might have shortened it a little to much now as theres more play in the peddle before i stop
Will get there soon, thanks for the advice guys.
Gabi_323i
i really don't understand why the oem servo can't fit with the m50?
- Homo Hair
its too large and fouls on the inlet
Gabi_323i
i have no clereance isues with oem servo and m50
Toby_Unna
- Boost Junkie
post a pic up then
stevetigger
I bet its left hand drive!
jmc330i
Servo is still on the left side of the car.stevetigger wrote:I bet its left hand drive!
I guess if the engine was tilted away from the servo enough it would fit, but Im still not sure how it would all fit
James
'91 325i Sport
'91 325i Sport
stevetigger
OKK, second guess its a 325ix that he put the M50 in!
GmanBimmer
I fiteed a Mk 1 Golf GTi servo to my E30 today.
It does fit without modifying the spacer to the cylinder.
But , I did find that when I swapped my end on to the shaft, it was to short!
the GTi Servo seems to have a slightly shorter shaft!
I got round this by using the E34 end as they are extra long and you can cut the m down to fit.
Graham in Kent
E30 project M5
E34 520 SE
E36 M3 (SOLD)
Galaxy V6 2.8 (Selling)
Mk1 Cortina V6 (210hp without Nitro) 300hp
OO=[][]=OO
E30 project M5
E34 520 SE
E36 M3 (SOLD)
OO=[][]=OO
Gabi_323i
yes it's left hand drive, i used m50 from e34 and engine mounts from e36 325 and fits perfect
stevetigger
Same here but RHDGabi_323i wrote:yes it's left hand drive, i used m50 from e34 and engine mounts from e36 325 and fits perfect
