OBC
Cromanian
Post Wed Jun 28, 2006 7:11 pm
I would like to put an OBC into my 316i and was wondering what is needed to be done or what can be done to do this as I have located an OBC in a crashed 325i. ( This OBC in the one near the sunroof.)
Any help gratefully appreciated,
Cheers Daniel.
smithy318i
Post Wed Jun 28, 2006 8:47 pm
Forget about it.
it's a major rewireing process which runs through the length of the car, and IMO not worth the hastle of fitting it.
BTW its called a "Check Control Panel"
keith52
Post Wed Jun 28, 2006 8:48 pm
Daniel , the one you're referring to is will be quite diffrcult to retro fit unless the wiring loom has been fitted and its just then a matter of plug and play .Maybe someone else can give you better advice
ad318i
Post Wed Jun 28, 2006 8:49 pm
yeah the check control was in the main wiring loom of the car... deffo not worth doing it..
but if you want a obc they will go fine.. a popular mod on the e30
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
Cromanian
Post Wed Jun 28, 2006 11:44 pm
Would it work if I spliced the wires and connected them to thier relevant check wires?
ad318i
Post Wed Jun 28, 2006 11:46 pm
no there are no wires in the cars for checking....
its really not worth it..
brianmoore will explain to you better soon enough
smithy318i
Post Wed Jun 28, 2006 11:51 pm
Cromanian wrote:Would it work if I spliced the wires and connected them to thier relevant check wires?
the wires for the check control are extra and also instead of the existing wires.
Post Thu Jun 29, 2006 12:15 am
The coolant level and oil level sensors could be wired up without to much trouble, (assuming the engine has the sensors), but the sensors and wiring for the lamp checks are not fitted, and are part of the main body loom, as are the wires up to the roof for the panel.
Cromanian
Post Thu Jun 29, 2006 6:59 pm
Cheers for all the info lads.
