I'm about to change my fuel tank, anyone got any tips before i get stuck in.
Any problems i may come accross?
Cheers Jonathan.
325I SPORT FUEL TANK CHANGE
kidsinister
- Brianmoooore
You live in a salt mine? I've never had to wd40 anything in advance, although a little helps on the day.buster wrote:its a twat of a job.
I'd pay a garage if i had to do it again !!
WD40 every thing a few days before you start and be prepared to be off the road for at least 2 days.
It's an easy enough job, although the luxury of a four post ramp helps.
Disconnect pipes/wires under the inspection covers under the back seat, and the pipes in front of the left rear wheel arch.
Remove rear of exhaust, heat shields, centre prop bearing and rear of prop, then it's just one nut and four (?) bolts.
Check/replace rear steel brake pipes while it's out.
v8chevette
it looks an easy enough job to me, probably just a case of getting the car nice and high on axle stands to make life a little easyer.
- buster
Brianmoooore wrote:You live in a salt mine? I've never had to wd40 anything in advance, although a little helps on the day.buster wrote:its a twat of a job.
- Brianmoooore
The fixing hole for the in tank high pressure pump is the same as the old type transfer pump, if that's what you mean.ed325i wrote:can you fit the newer type tank to an early car ?
ED
- Brianmoooore
Yes, that's what I mean above.ed325i wrote:I just did know if I could convert to the later tank with the fuel pump in the tank.
ED
