rev limiter?
craigieeb
Post Fri Mar 11, 2005 8:33 pm
where is the rev limiter??? is it controled via the e,c,u or is that a totaly silly question,
and secondly how do i remove it :twisted:
Toby_Unna
Boost Junkie
Post Fri Mar 11, 2005 8:36 pm
just put a viper chip in my 335 ecu and the rev limit increased from 6.2 to 6.5+
so i guess it's set by the fuel mapping chip.
craigieeb
Post Fri Mar 11, 2005 8:41 pm
Toby_Unna wrote:just put a viper chip in my 335 ecu and the rev limit increased from 6.2 to 6.5+
bugga there's me thinking i could just whip of a sensor or something
Richy325iTouring
Post Fri Mar 11, 2005 11:15 pm
mine went from 6500 to 6750 with the zone chip
Andy335Touring
Post Fri Mar 11, 2005 11:18 pm
If you have a word with Ant i think he can write you a chip with a rev limit of your choice ?
Richy325iTouring
Post Fri Mar 11, 2005 11:21 pm
might have a word with ant and see if i can get more power
craigieeb
Post Fri Mar 11, 2005 11:24 pm
i think i might do that because the notrous realy comes on form at about 5 ish, and then obviously the limiter kick's in not long after, so i would want a prity high limit
Andy335Touring
Post Fri Mar 11, 2005 11:28 pm
Can't the noz be turned on earlier ? Say 3500-4000rpm ?
craigieeb
Post Fri Mar 11, 2005 11:34 pm
well iv got it set at the mo so when im full throttle it kick's in, and with noz you cant bring it in before 3k or it will detonate the engine, but when it come's in on full throttle @ around 3.5k it kicks in, but then it seems to have a second wind around 5k and thats when i can feel it the most
Andy335Touring
Post Fri Mar 11, 2005 11:37 pm
Has it got some form of progresive controler on it ?
What sort of BHP jets are you using ?
Andy335Touring
Post Fri Mar 11, 2005 11:39 pm
What mods has the engine got besides the noz ?
craigieeb
Post Fri Mar 11, 2005 11:40 pm
iv got some controlers there but there not wired in yet (a job for tomorow)
and im running the 70 horse jets
craigieeb
Post Fri Mar 11, 2005 11:42 pm
Andy335Touring wrote:What mods has the engine got besides the noz ?
well it's been ported out, iv got a cam in it, 6 branch and a 3"straight thru exhaust
but i want more i tell you
Andy335Touring
Post Fri Mar 11, 2005 11:52 pm
Sounds a nice set up,i'll bet it shifts well ! 8)
More,more,more ! I'm the same mate,got to keep doing some thing to it.
Today swapped my dif from a 3.25LSD to a 3.64LSD,pulls a lot better now :twisted:
craigieeb
Post Fri Mar 11, 2005 11:56 pm
iv just actually been offerd a 3.64 slipper, does it make a lot of diffrence?
im still running a standard diff :roll:
Andy335Touring
Post Sat Mar 12, 2005 12:05 am
Definatley a worth while thing to have,will help you no end putting the power down when the noz kicks in i'd have thought ?
craigieeb
Post Sat Mar 12, 2005 12:10 am
i'll see what my finances are like after the weekend then eh
and i was thinking about, poss a sport gearbox as well what do you recon?
Andy335Touring
Post Sat Mar 12, 2005 12:31 am
I was going to post you a link to a cool gearing calculator so you could have a play with it to work out what sort of ratios would be best for you but the link doesn't work ! :cry:
Heres some of the figures i worked out for mine with it.It's copied from an email i sent.
craigieeb
Post Sat Mar 12, 2005 12:36 am
hey thats great andy nice one fella :thumb:
Toby_Unna
Boost Junkie
Post Sat Mar 12, 2005 12:46 am
that diff a bit better then andy winkeye
is it quieter than the last one?
Andy335Touring
Post Sat Mar 12, 2005 12:50 am
Toby_Unna wrote:that diff a bit better then andy winkeye
Yes and yes !
With thanks to ScottMc,top bloke !
Paul325i
Post Sat Mar 12, 2005 11:01 am
I wouldn't put a 3.64 diff in a car that you have setup for all top end power, you'll be constantly dropping out of the power band, you'll be better off with a 3.91.
Don't run NOS for to long without the controller either, to I've seen the mess it can make of an engine (holes in pistons, melted valves)
And not alot of point making the rev limiter any higher that 6750 as the M20 won't be putting out any real power then, plus if you go up past 7krpm there is a good chance you'll spin it to bits if worked hard.
Toby_Unna
Boost Junkie
Post Sat Mar 12, 2005 11:24 am
andy's 3.5 has plenty power right through and was bloody quick with a 3.25 diff, i don't think it's going to struggle to pull a 3.64
mine on the other hand has the same box but a 3.91 and feels undergeared, it will get to the limiter pretty quickly in top.
don't know about craigs though!
Paul325i
Post Sat Mar 12, 2005 11:29 am
Yeah sorry i was talking about craigs car mate, not the 3.5!! lol
