tuning a 1.8 m10???
m4ddesigns
anyone no of any good tuning nits for a 1.8 carb m1o engine???
Si316
what kind of things are you looking for mate? bolt on parts? or parts for a full rebuild? theres loads of stuff out there for these screaming 4 pots!
m4ddesigns
whatever i can get mate lol
craigieeb
you can get an extra 2 cylinders
M50 Turbo!!!
I shall say no more
Widge
craigieeb wrote:you can get an extra 2 cylinders![]()
Or move further north where the air is colder and denser = more power
craigieeb
Widge wrote:craigieeb wrote:you can get an extra 2 cylinders![]()
They make all the difference.
mmmmm induction roar
M50 Turbo!!!
I shall say no more
Si316
Well if your after afew bolt on bits then id say get a free flow filter and exhaust and a good setup on some rollers.
If you wanna go for a full rebuild then find yourself the crank and pistons from a 2002 2.0l m10 and rebuild the engine with them. stick on a 318i head with a nice cam and it'll make a wicked little engine. You can go further for more power but it depends what your budget is.
m4ddesigns
is the bottom end the same on the 316i and 318i engines? if i use the head can i still run the carb set up? as i want twin 45s in the end?
Si316
the bottom end is the same on the 316 and 318i (both 1766cc), there was no 316i m10 in the e30. The heads are different with the 318i having bigger valves.
