t34 or t38 or t4 turbo replacment or other suggestions?
fuzzy
He who sleeps with "Gingers"
Post Sat Jun 24, 2006 5:34 pm
following on from my turbo topic the other day,looks like i tempted fate as my turbo is giving big puffs of blue smoke on full boost and there is oil in the boost pipes and the intercooler,bollox :cry: ive just been looking at prices and a direct replacement for the t34 i already have is £765 new but im also considering an upgrade to a t38 which is £1150 new.i know which one i want but im struggling to justify it.ive also seen a t4 hybrid with external wastegate thats allegedly new for a extremely cheap £850, or is there a direct replacement Holset turbo thats available for the cosworth? whats your opinions?
Ant
Retired Team Member
Retired Team Member
Post Sat Jun 24, 2006 7:15 pm
HX-35W All the way mate
internally gated.
What are the wheel specs for the next upgrade from the T34 ????
fuzzy
Post Sun Jun 25, 2006 12:39 am
just looked on the holset site and it lists the HX-35W as having a hp output of 280? unless ive got the wrong end of the stick then thats a little bit on the small side :?
Ant
Retired Team Member
Retired Team Member
Post Sun Jun 25, 2006 1:17 am
Double the output quoted for Petrol dude
Fozzy runs an H1C the HX I have is bigger, Marks turbo is easily capable of 30 psi on a 2.5 with boost to spare, efficent range quoted 15-31 psi iirc.
Chek out to compressor maps Fuzzy
The T4 route is proven, but its a very old design of turbo.
fuzzy
Post Sun Jun 25, 2006 12:18 pm
compressor maps and technical stuff go way over my head im not that technically minded,im more a if it doesnt work hit it until it does sort of person :mad: .would using a holset turbo mean id have to get another manifold or would it fit my cossie 4wd manifold directly ?
Ant
Retired Team Member
Retired Team Member
Post Sun Jun 25, 2006 12:39 pm
H1C and HX35 series are T3 footprint on the turbine so bolt on mate
do you have the pecs on what you have ?
comp wheel size ? trim ? A/R etc for both hot and cold
T34 is normally t3 back end in 58mm size and 0.52 A/R wih small compressor ( 60mm ish ) in 0.67 A/r housing
HX 35 W specs are:
Comp 82mm housing is 0.82 A/R tubine 72mm in 0.91A/R
in english:
HUGE compared to even the Rs500 T4 unit, but much more modern design , lower rotating inertia , less lag and much more boost with much reduced charge temps
More power :cool:
fuzzy
Post Sun Jun 25, 2006 12:46 pm
i have no idea on the spec of my turbo other than what i was told when i bought it that its a stage 3 t34 :? could be a bean can with a fan in it for all i know though winkeye i do understand more power though so what sort of price do holset turbos cost ?
Ant
Retired Team Member
Retired Team Member
Post Sun Jun 25, 2006 12:50 pm
Take some pix Fuzzy
there should be an I.D plate on the thnag somewhere with the assy no.
the A/R will be cast into the housings.
there are a lot of T34 hybrids on the market, who supplied the unit ?
I have the specs for the std 4WD sapphy unit, its what I'm using currently
if you use a bigger turbine side, the boost comes in later but stronger, less torque but lots more top end HP
depends what you were wanting to achieve dude ?
fuzzy
Post Sun Jun 25, 2006 1:23 pm
it has AR0.63 on the exhaust side there is a tag with nothing on it and M27 and 93 on the inlet side,not sure if that means much though.im looking for low down boost for quick acceleration rather than lag with more top end .my engine is 2WD but has a 4WD manifold for inner wing clearance issues.my ultimate aim is around the 400 bhp figure,give or take a few horses,all suggestions greatfully recieved winkeye
fuzzy
Post Tue Jun 27, 2006 7:01 pm
in the end i decided on a direct replacement so today i bought another t34 with 360 degree thrust bearing and cut back blades, i have no idea what that actually means but it sounds impressive winkeye .by the time i also bought some new samco hoses its cost me the thick end of £1000 8O .the good thing is its a brand new turbo so i can keep the old one to take apart and fix up myself as a back up 8) i now need to put in some overtime at work to pay for it :cry:
