Removing door lock..
- Homo Hair
Removed the door loom so far (some plank cut the wires rather than unplug the connector
) But am a bit unsure how to remove the lock so i can put the one from the car in..
fowler
- Boost Junkie
what you taking out jon the lock or the barrell
EX A-Tech Workshop bitch !!!
gone but not forgotten
- Homo Hair
barrel the key goes into..
fowler
- Boost Junkie
there is a c clip mate that hold it in place the poop that off and undo the atcual ock on the door an you should just be a case of a 10-15 min job of changing the barell
Chris-W
