Right, first of all a massive thats to Daz, for not only sorting a relay for me but also getting it here for this morning! seriously appreciated chap!!
However, it seems this isn't my problem
since yesterday it's been doing it everytime i drive it, it hasnt actually cut out again, it only ever did that the first time bizarrely enough, but anything above 4k noe results in a chorus of misfires and its clear below that theres a noticeable loss in power and you can feel it hesitating. And it doesnt matter if shes hot or cold its the same everytime.
So on fitting the new relay i knew straight away i'd know.. and at the first turn of the key i thought it was problem solved.. as the car settled down straight away to 800rpm idle and no funny noises from the zorst (before the car had an almost rotary sound to it at idle) but the power loss in scond was there by the end of my road along with its friends the misfires
and after a 5 min drive it was warbling at idle again.
So, my next question, how good are the ecu's on e30's when it comes to picking up fault codes? i want a diag done and don't mind spending £40 if i'm confindent it should display the problem, as im thinking maybe the dizzy or the actual DME unit now, along with maybe the crankshaft sensor as someone mentioned.
Is a diagnostic check the next thing i should do?
Thanks in advance guys
ps. Daz i'll send the relay back asap
