a/c switch q
FESI
are these a/c & recirculating buttons supose to iluminate when the lights are on or only when they are in function (pressed)
thanks
thanks
Gwynleym10
Just when they are pressed I think, like the rear demister switch
Cloggy Saint
GDBN
But the top "blue" aircon switch only switches on when the direction levers are set in a certain way. Nothing towards the windscreen and the mid and/or lower vents must be open.
Cloggy Saint
You sure? I'm pretty sure mine works no matter where the slide controls are.GDBN wrote:But the top "blue" aircon switch only switches on when the direction levers are set in a certain way. Nothing towards the windscreen and the mid and/or lower vents must be open.
GDBN
Yes mate ... if the control to the windscreen is even slightly open it should switch off the ac ... something to do with the windscreen cracking.
Other vents have to open or I get no blue light.
Says the same in the user manual too I think
Cloggy Saint
mrLEE30
thats only on certain (probably uk) models. both mine have factory A/C and work in any position. and to confirm the lights only light when on. also on both mine if the recirculate button (yellow) one is turned on the fan will run and the A/C compressor will run even without the AC switch on.
mrlee
mrlee
Demlotcrew
I cant see this happening, i would want AC on while im trying to demist the screen as the AC dries the air very fast and clears the screen better than with the AC off.GDBN wrote:Yes mate ... if the control to the windscreen is even slightly open it should switch off the ac ... something to do with the windscreen cracking.
Mines works with any sliders open/closed. But i do have Climate control, so it might be different because on mines only the lower slider has a circuit board attached to it to sense the position of the vent.
Andrew
Cloggy Saint
E30Mark
you will have numbers around the perimeter of the blue/red label on the heater temp' knobdatourer wrote:How do you know if you have climate control?
PM for details
PM for details
Cloggy Saint
Chris-W
And if a car has the numbered ring but no A/C?E30Mark wrote:you will have numbers around the perimeter of the blue/red label on the heater temp' knobdatourer wrote:How do you know if you have climate control?
Ant
- Retired Team Member
easiest spot for the "climate" ( very loose term... ) is an extra small bore vacuum take off near the check valve on the servo supply line, should dissapear into the bulkhead.
Email FTW
FESI
so how can we make the switches to light when main light is on, is there some trick like for the rear dem. switch
ian332isport
Regarding the switch illumination, I still need to have a good look and see what's possible. As standard they only light up when you press the button.
As far as the A/C only operating with the sliders in a certain position. This is a pre/post facelift thing. Early cars need the sliders in a certain position, but post facelift cars will operate in any position.
Cheers,
Ian.
Cheers,
Ian.
Cloggy Saint
Ant
maybe a touring rear w/wipe switch would provide the required gubbins ?
Email FTW
