took these the other day:
Cheddar meet at the start of the year:
e36 318is vs e30 318is
new 2.1 engine:
throttle bodies:
on sheps' rollers:
[img]http://
cheers! no doubt will see you at the next one!iDreamBeemer wrote:Looks well nice mate. Shame I missed checking it out at the Cheddar meet (nice to see mine in one of the pics! - the only red e30 there)
How does the extra weight from the conversion affect the handling? Still got the good balance or do you notice the front is heavier?
thanks! talking engine only - not ITBs etc i must admit it cost me more than i anticipated, but i did everything properly. got stung on pistons which came from the states, got taxed £70 on them cos the guy in the states insured them in post for more than i paid for them, paid too much for rods, paid too much for machining and the crank work. total was about £1.5k including buying the spare engine etc. but that's with absolutely no corners cut, and i count everything, i havent forgotten the odds and sods that add up! i also got a few hundred back in parts left over, and still have a few parts to flog on. had i gone for a tamer spec it would have cost less. fuel economy is pretty much unchanged, better if anything on the motorway, possibly worse when giving it some beans. i've actually done about 2k on it so far, its on its third load of oil. it does near 40mpg on the motorway, around 30mpg around town and when messing around. im very happy with it, its the most sensible mod to do engine-wise really unless you want to make a 1.8 screamer. and its now totally unique, the only one in the UK etc.dark_sounds wrote:they are going to be added to my e30 picture collectionfantastic pics!
btw dude, how much it all cost in the end? and how long it take you to do such a procedure??
hows the economy after doing 1000 odd miles! lol
cheers! well the engine bay has been resprayed (by me with rattle cans!), and all the covers etc on the engine likewise have been repainted. it used to be well yellow and manky in there! as for the drop im not sure, anyone want to hazard a guess? i'd say about 40mm all round. wheels are 15s, tyres 205/50/15s.Sanchez wrote:Hi tim awsome car, shame my bays not as clean as yours, Whats the drop and what tire sizes you got , looks better than mine, but thats cause i think yours are 15's and mine only 14's. DO you have sump vs speed hump problems?
no, the car has a pretty different character now, no longer has nothing down low and the sudden sense of urgency when you wind her up at higher rpm. its a bit sad in a way, but i'll get over it! in reality its so much nicer to drive like this! you can overtake in 3rd/4th where 2nd used to be required, and still go just as quick. above 4,500rpm it feels a bit faster than standard but not much. i hope to help it higher up the revs when the headwork/cams/itbs are on, i think the fuelling at the moment (still on moptronic until i pull my finger out and get MS maped) probably doesn't help either.appletree wrote:That looks very nice. where does the power realy come in? is it still around 4000/4500rpm or is it any lower? also is that just a back box or is it a full system? who's it made by? am realy strugaling to find any one who stocks exhusts for the IS apart from having one custom made!
hi stuart, not sure how much of mine's spec i'll give away, its a bit special and i may keep some of my cards close to my chest on this one - not sure yet. i have no probs giving out info to help with projects etc though of course, and i'll help you along! fwiw, m47 crank needs work to fit, m47 rods are no use for our engine. m47 crank woudl up the capacity to 1.95l if you got a rod/piston combo sorted.stuartgallafant wrote:tim, you're car is looking sweet dude!! you must be chuffed with it!
stiil trying to find the time to play with my M42, but im so bloody busy all the time, i just dont get a chance! anyway, what went in yours in the end? was the M47 crank and rods or something else?
if you can pm/post a spec list up, i'd be well interested to see it
everything is different on my bottom end. different pistons, rods, crank, block decked etc. you can go a little bit further capacity-wise, but i wanted factory reliability from mine.stuartgallafant wrote:so how did you get yours to 2.1 then tim? and thanks for the offer. i'll DEFO be taking you up on it!!
lol, doing bottom end work to the m42 you can forget doing it on the cheap imo. it just won't happen! 1.9 is fairly easy, 2l a bit more involved and 2.1 more expensive again, but you also have to bear in mind that on whatever you do the parts and machining costs will be high. whatever you do to the bottom end, you'll probably be facing about a £1k bill minimum.stuartgallafant wrote:i like the sound of what you've done to yours. i would like the extrra torque that you've managed to get, and i also want reliability!! thing is, this also needs to come at good price, unless i drag the project out for slightly longer!
im also thinking about ITB's, but ive heard thats an expensive conversion?! but it does make me wet my pants!!! definately the way forward!!
[img]http://
Would love a turbo too..I'm still in the process of stripping the engine, got the inlet, injectors all that sort of stuff off, will the engine be ok sitting outside, but covered up (good)? also is there much involved with taking it apart and then putting it back together...tim_s wrote:Cheers Pal! what you got in mind for yours then?
btw if you need any work done, im in between jobs atm and so am open to making some pennies doing car work for people!
[img]http://
