HELP HELP gearbox and diff problems on turbo is
318isturbo
Post Mon Jun 05, 2006 11:36 pm
hi all here's one to get your heads round im putting my stage 3 turbo upgrade to my e30 318is but i have been told that the gearbox and diff may not handle it.As it will be running about 270bhp.
does anyone no of any other models of e30 that will fit on mine such as 325i or 325is as i honestly aint got a clue if there is anyone out there who could help that would be great.
dubzy1981@hotmail.com
Pal318is
Post Tue Jun 06, 2006 7:22 am
Can't help to much with the answers you need...Apologies, but your conversion does sound good....Keep a log in the Engine Swp section of the zone...
Pal
Image[img]http://Image
Gwynleym10
Post Tue Jun 06, 2006 10:03 am
Sounds like a good project, you'll have to post specs up!
If you have a large case diff, I suspect you'll need at least an m3 one for gearing you will be fine.
As for the gearbox, I'm pretty sure nothing else will fit. But i might be fine, with regular fluid changes!
Would have thought the clutch would need uprating though
London 2 Cape Town
www.Overlandinthesun.com
e30_Turbo
Boost Junkie
Post Tue Jun 06, 2006 10:21 am
M3 diff will be fine as thats what the Swedes use on there silly power conversons and I'll be joining them soon. :D
Gearbox's I'm not sure about, hmmmm, this is a question for the real guru's of e30 land!
Glad to see another turbo tho!
HTH, Mark.
Andy335Touring
Post Tue Jun 06, 2006 8:38 pm
fozzymonster wrote:M3 diff will be fine as thats what the Swedes use on there silly power conversons and I'll be joining them soon. :D
winkeye
Paulsimon8
Post Wed Jun 07, 2006 1:10 pm
M3 diff will be fine for use. I'll be putting 350 horses thru mine very shortly winkeye winkeye winkeye
If you can get hold of one, the larger diff cover with the massive cooling fins - your diff will love you for it winkeye
One of these badboys winkeye
Post Wed Jun 07, 2006 5:19 pm
thats a ZM3/coupe back plate cover £100 from the dealer with the stonger rear bush in it also
as it's a 4 pot i can't think of a gearbox which will bolt straight on, as the 2.5 boxes can handle the power your car will be running
M3 diff is all ok but the ratio will be well out if you can't use a gearbox like the dogleg unit no?
Nelly
Gumbo
Gumbo
Post Wed Jun 07, 2006 6:21 pm
Even a 3.64 LSD should be fine in it as for the g/b, if you wanted to go down the route of an adaptor for the bell housing and use some thing along the lines of a cosworth g/b - not heard of it done before with the IS engine but, with the old sckool v6/v8 conversions this was a good/strong mod.
Only thing is you'll be shelling out to get the prop shaft shortened and balanced to allow for a different g/box
Neil.
"I F**KING LOVE YOU GUMBO"
Motorhole
Post Wed Jun 07, 2006 6:24 pm
Its torque that kills diffs and gearbox, not power (As such...).
M3 diff is great, wassisname with the LS1 engined M3 (411bhp and nearly 400lbft torque) uses one.
Once more, not sure about boxes...though looking in the owner's manual, all the boxes are the same ratio apart from the sport box fitted to the 325is and 318is (is that right?) which insinuates that they are the same 'box? :roll:
