Number plate anti-camera spray
fuzzy
He who sleeps with "Gingers"
Post Sun May 28, 2006 2:34 pm
i wouldnt deny speeding is a major issue in a lot of crashes ,but your right in the fact that is drivers misjudging the conditions,there is a right time for everything,and its not when the roads are busy with other drivers or conditions are bad :wink:
Rich_W
Post Sun May 28, 2006 6:30 pm
To try and get this back on topic. :cry:
The only number plate device Ive ever seen work was fitted to the Polizei M5 at the Gumball last year.
Look at the plate straight on (as in being followed by a Police Car) looks fine
But as the angle of attack changes (i.e for a Gatso mounted off to the side or on a Motorway Gantry) so does the visability of the numbers
The item does have some weaknesses at some angles. So its not a 100% success rate.
Crucially it also passes the "negative test" the police are allowed to use if a photo is particularly over exposed
In the interests of not getting the Zone into trouble I wont be revealing where or how to buy this product. But a search on Google may be your friend :wink:
bmwe30mtech
Post Sun May 28, 2006 6:45 pm
Those plates seem to work quite well. I personally wouldnt use them, but they look like they would work. Untill a police car sees them at an angle :P , then your done!
Paul
Steve-E30
East Sussex Hooligan
Post Mon May 29, 2006 4:18 pm
Problem with the spray is .... If you are followed by the police your plate will not show on the onboard cameras apparently , Thats coming from a friend in the force , Ok maybe you escape a few gatsos but what if you get a tug , Defacing your reg. plate is an offence :wink: Just a thought guys :wink:
andyp
True Old Skooler
Post Mon May 29, 2006 5:59 pm
NIX wrote:Anyone know whether the stuff you can buy to spray on number plates to stop speed cameras working out whats on your number plate, actually works??
Cheers!
Nick
the spray and the anti flash plates DO NOT work as i have the points to prove it,
Grantley
Post Mon May 29, 2006 8:18 pm
It looks as though those plates may work but if you were caught using them the trouble you would be in is far worse than a poxy speeding fine and three points. As far as I know the charge would be obstruction and you dont wanna be charged with that !
