Retro-fitting Cruise Control
AndrewL
Post Sat May 27, 2006 11:35 pm
Can one of the experts please tell me (in detail) where the cable goes through the bulkhead? Below and to the left of my fuse box I only seem to have one hole through the bulkhead and it already has quite a few things running through it.
Many thanks for your help,
Andy Lee
Post Sun May 28, 2006 12:34 am
If you look at the big rubber grommet through the bulkhead from the glove box side, you will see it has a number of partly formed holes.
I'm not familiar with the cruise loom but would expect it to have a grommet on it which should match one of these part cutouts.
You will have to finish removing the rubber from the appropriate hole with a scalpel or similar.
charlE30
Post Sun May 28, 2006 8:30 am
Brianmoooore wrote:If you look at the big rubber grommet through the bulkhead from the glove box side, you will see it has a number of partly formed holes.
exactly as brian describes and use a bit of wire to pull the loom through, it's a tight fit and a bit fiddely but it does go :D
BMW F31 335d xdrive
AndrewL
Post Sun May 28, 2006 4:09 pm
Many thanks guys, I'm planning to do the "inside" fix tomorrow; did the under-bonnet bit yesterday..
Andy
