I just had the guy from the garage on the phone reckons my powersteering pump is nackered, how do i tell this?
I know they never really worked that well plus mines got low profile tyres on it so it doesnt help. Ive had it in an independant BMW specialist before and he's driven it and never said anything what do you guys reckon?
It is really stiff to turn when stationary and i have to really tugg on the steering wheel i was wondering what others think before i go down and see him tomorrow?
Power steering
dazleeds
- old skool raver
stiff to turn
noisy squeals sqeaks and creaks are all signs
could just be manky fluid tho??
usualy noisy in my experience if pumps knacked
www.oldskoolfantasy.co.uk
t11mfn
Daz that is what i thought i cannot hear any noises from it, i thought it was stiff cause of the tyres like i said and the lower suspension it was way worse when i had it 60/60 drop.
I will have to see what he says tomorrow when i get there!
dazleeds
- old skool raver
mine was same recently
turned out everything was fooked
but that was making a racket
if yours isnt i would try flushing the fluid and putting some new in before forking out for rack etc
also check the tierods are in gd condition they could be getting stiff if they have dried up on the joints etc or have any splits
this is all things i was told to check when mine was playing up
prob will feel stiffer than standard with the drop etc but shouldnt be much difference not as much as you have anyway
good luck
good luck
t11mfn
He reckons its the pump thats fcuked?
What do the tierods look like? im being completley stupid now
dazleeds
- old skool raver
tierods are the bars that link to the rack and to the wheel hub assembly
1 adjustable bar each side for tracking etc
they have a balljoint in them
check the rubber boots arent split as this could cause them to stiffen up if grit dirt gets into them
t11mfn
Ive just had new track rod ends mate is this what you mean?
dazleeds
- old skool raver
ok well thats them eliminatedt11mfn wrote:Ive just had new track rod ends mate is this what you mean?
so were back to fluid/rack/pump
t11mfn
Daz -> Apparently when i got it back to the garage the pump was nackered and when they took it off they saw why. Some dopey idiot has put normal oil instead of ATF oil what an idiot.
Subsequently the rack is dead tooo so thats another new one of those.
The amount of money i have spent on my car since august last year is not worth thinking about i tell you!! Mind you it will be worth it in the end.
Morat
