Convertible trouble: Electric lid, electric folding top!
koenvandermolen
Post Wed May 24, 2006 4:45 pm
Hi guys,
I've searched a lot of technical forums but unfortunately I still haven't been able to solve my convertible problem.
I bought my 91'er convertible without a working folding top. The levers were detached and everything was delivered in a box.
There is another topic on this forum wich helped me alot, but still I'm having one big problem: The lid. The electric lid makes a ticking sound whenever it has to work hard (ie closing the clid and opening it) I'd like to operate is, but i cant remove the levers wich operates/seals the lid. I removed the screw but still I can't get it out. I need to remove them in order to remove the lidmotor.
any ideas?
Thnx in advance,
Koen
[/img]
fowler
Boost Junkie
Post Wed May 24, 2006 4:53 pm
where are you based as i know a hood specilaist that evn BMW USE
EX A-Tech Workshop bitch !!!
gone but not forgotten
koenvandermolen
Post Wed May 24, 2006 5:15 pm
unfortunately i live in Maastricht, the most southern city of the Netherlands.
fowler
Boost Junkie
Post Wed May 24, 2006 6:01 pm
Hello mate well take a picture and i will run through how to get it off as the doo bend and they vare a pain in the butt to get off
fowler
Boost Junkie
Post Wed May 24, 2006 6:04 pm
hello mate have a look at the lnk below
http://www.realoem.com/bmw/partgrp.do?m ... g=54&fg=10
might help you
DaveD
E30Zone Wiki Specialist
Post Wed May 24, 2006 7:24 pm
I am sorry to say that you need a new flap motor ...the one thats situated in the middle..it has stripped some of the gears internally they can be repaired if you know someone CHEAP but it is usually cheaper to buy a new (secondhand ) motor...i had to
try this guy if you cannot get one locally
The E30 BMW CENTRE
M6 Junction9
Darlaston West Midlands
tel 07968 852395(bill)
07871 662902 (jason
£50 last year
MARTYCAB
Post Wed May 24, 2006 7:41 pm
hello there hope this may help you a little me and my mate had this problem last week when we were fixing his hood we took off the motor and turned it by hand then it started to slip . looking at it i saw the frame was bent a little so i then drill a hole fitted a m6 bolt and nut . we then dun the nut and bolt up this allows the gear box + motor to clamp together better when tested it worked fine and touch wood is still working no clicking noise . so try this first as its cost free hope this is a help.
koenvandermolen
Post Wed May 24, 2006 9:01 pm
i made some pictures of the situation. But how can i post them here on the forum?
DaveD
Post Thu May 25, 2006 8:34 am
have you looked at the links on this thread...also you get at the flap motor from the boot ...they just drop down
http://www.e30zone.co.uk/modules.php?na ... highlight=
http://www.e30ic.com/powertop.htm
I will see if i have any other info later
koenvandermolen
Post Sun May 28, 2006 2:57 pm
Hi there!
Thnx for the posts. Though I still haven't been able to remove the hood lever. I've found the numbers of the items on this link:
http://www.realoem.com/bmw/showparts.do ... g=54&fg=10
I can't remove the levers (#4 and #10). I have removed the screw but still the things are stuck as hell.
Has anyone any idea how to solve this puzzle?
Thnx in advance guys!
DaveD
Post Sun May 28, 2006 4:23 pm
Brute force...or try heating it
koenvandermolen
Post Mon May 29, 2006 11:46 pm
but it is not fixed from the other side? So the screw is the only thing spoling my operating party?
will some liquid N2 work?
DaveD
Post Tue May 30, 2006 12:09 pm
it looks like it from the drawing...i will have a look at mine when it stops raining
Quaser
Post Tue May 30, 2006 4:37 pm
there is an allen key bolt that goes in there. If you have rounded the head off - then get a torq adaptor slightly bigger then the allen key head and hammer it in.
I had to do this to change my #4!
Q
