Me being me I had to give the engine a bit of a clean up so it was completely stripped down as far as possible without removing the head or the sump. Next the whole engine was degreased and the block was painted satin black. Various brackets were also painted aswell as the rusty bit of the alternator. All alloy parts were cleaned up and copper brushed.
All new parts fitted were:-
Timing belt and tensioner
Thermostat housing, gasket and cover
Thermostat
Blue and brown temp sensors
Water pump gasket
Inlet manifold gaskets
Throttle body gaskets
Exhaust manifold gaskets, studs and nuts
Rocker cover gasket
All possible nuts, bolts and washers replaced with stainless steel ones
Stripped and ready for paint
Painted and ready for re-assembly
Timing belt, tensioner, belt covers and thermostat housing fitted
Inlet manifold and alternator fitted
New manifold studs and nuts fitted
All plumbed up and wired and ready for insertion
A couple of problems were encountered along the way
1. I snapped the middle stud while removing the inlet manifold. This was drilled out ready for re-tapping but I drilled too big a hole and had to take it up from a M8 thread to a M10.
2. After installing the engine and while trying to bleed the cooling system I found a leak. The hole on the thermostat housing for one of the blanking plugs had been drilled too close to the edge of the body of the housing and did not leave enough flat surface for the copper washer to seal against.
Apart from that pretty straight forward although time consuming.
P.S. Apologies for the long post but there have been longer, less interesting posts than this before.
Taylor.
