OK,
I have just fitted a new OBC outside temp sensor, and also notice 2 more wires coimg out of the same part of the loom where something seems to of been ripped off at some point..!!
What is missing as the OBC still reads -30!! or do i need to give it time..
Thanks guys
OBC Outside Temp sensor
Cloggy Saint
Stealth
So is there more than one horn as the main one works..??
Do i have to check the wiring back to the OBC as everything else works on it.?
Cloggy Saint
The auxiliary horn for the obc is part of it's immobiliser system, and not worth worrying about if you don't have it. It sounds to me as if you may have a dodgy sensor in the air duct, providing everything is correctly wired.
Stealth
OK thanks, will get back to the guy on e-bay who sent it to me and said it was a fully working one.>!!
Cloggy Saint
Stealth
ok, will do.. thanks
