OBC Outside Temp sensor
Stealth
Post Mon May 15, 2006 7:01 pm
OK,
I have just fitted a new OBC outside temp sensor, and also notice 2 more wires coimg out of the same part of the loom where something seems to of been ripped off at some point..!!
What is missing as the OBC still reads -30!! or do i need to give it time..
Thanks guys
ed325i
Post Mon May 15, 2006 7:21 pm
They go to a horn.
ED
Cloggy Saint
Post Mon May 15, 2006 7:56 pm
If it's reading -30 then there is a fault somewhere as the obc isn't recognizing the temp' sensor.
Stealth
Post Mon May 15, 2006 9:04 pm
So is there more than one horn as the main one works..??
Do i have to check the wiring back to the OBC as everything else works on it.?
Cloggy Saint
Post Mon May 15, 2006 9:14 pm
The auxiliary horn for the obc is part of it's immobiliser system, and not worth worrying about if you don't have it. It sounds to me as if you may have a dodgy sensor in the air duct, providing everything is correctly wired.
Stealth
Post Mon May 15, 2006 9:16 pm
OK thanks, will get back to the guy on e-bay who sent it to me and said it was a fully working one.>!! :x
Cloggy Saint
Post Mon May 15, 2006 9:17 pm
Check all connections before letting him have it!
Stealth
Post Mon May 15, 2006 9:20 pm
ok, will do.. thanks
