29/4/06
Right its been a while since any update here from me so here goes.
Got a new cut off switch ordered (FIA compliant) as the old one wasn't going to take account of alternator run-on etc. so risked damaging the electrics when I use it.
So the new one takes a feed from the ignition circuit, the main battery cable, and also sends any the alternator current through a resistor to ground when in the off position.
I spent absolutely ages (I mean days) fiddling around trying to work out what to do. In the end I re-routed another bit of cable from behind the dash to the old battery location under the bonnet and mounted new connectors inside the car behind the dash. Lovely jubbly you might say!!
NO...you're wrong. Not lovely fcuking jubbly at all. Spent another couple of days cutting an alumunium panel to go on the dash. In the end it looked crap. So I ditched it. Luckily my brother in law is a yacht builder (builds for the Beckhams and such like) so he is getting me a new piece laser cut (which is what I should of done in the first place).
So I just connected everything back up and we were away again.
Then I properly mounted the battery in the boot. I ended up using a six cyclinder tray but I added two clamps (one on each side of the battery) as the battery I am using is smaller than the standard six one and I wanted no risk of it moving in the event of an accident. I also belt and braced it with another strap (probably overboard but its that fire paranoia kicking in again).
Then maanged to get the dashboard back in so it was usable to drive over to my new house. Then it got shut up in the garage for a bit.
So thats sorted for the time being. Then I spent a bit of time just clearing out the old crap from in the car.
Next job was the remainder of the sound deadening. The rear seat looked like this when I left it:
which I wasn't really happy with. So I spent ages (hours and hours and hours) cleaning it until I ended up with this:
Much much better but now it means I have to do the rest of the car
Cleaned up the remainder of the headlining as well as it had loads of stick bits left on.
In the meantime I managed to pick up some new wheels for it as well for road use only(17" Borbet C's). They are not on yet as I have to get some spigot rings but here is a cheeky preview
Then it was time to sort the front wing. Here you can see the problem:
Now took the bumper off and the old wing off. Was looking at the bumper wondering whether to cut it down or not (ala 316) but at the moment decided not too.
Also sprayed the grills black
Also took my roll cage back out as I wasn't happy with the quality of the welding on it. Got the neccessary brackets and stuff re-welded:
Much better
And the is the current state of the car. I am hoping to receive my door and wing back sprayed this week so will crack on with getting them back on.
I seem to have spent days (probably about 20) since my last update working on it but the progress seems to be slow at the moment. I seem to spend a lot of time taking the same old bits apart and putting them back together again (i.e. seats in, seats out, back in no out again) so a time of is wasted doing that. Also I am at the stage where all the ripping out is done so its the little bits left over.
Ah well its all fun. Problem is I haven't been out on track in it at all yet this year and time is ticking. My plan is that by the end of May it will all be ready (bar the coilovers which I hope to order soon)
And finally. Got my new trolley jack at last. My old one never fitted under the car so I had to jack it up using the crappy BMW jack first!!
New Sealey 3ton low entry jack arrived (lovely and low)
