engine mount problem help please
dark_sounds
Post Tue May 09, 2006 10:32 am
since my mini bump, the engine was moved forward...
in order to remindy this i undo the mount, lift the engine up, (block of wood and a trolley jack under the sump, )
it came undone from both ends, however cant get it to sit back on top of them, need to move the engine to the back slightly, both holes and mountings are quite off.
anyone know what i can do now?? or even better, can anyone give me a hand!? (croydon area)
Globulator
Post Tue May 09, 2006 11:54 am
You may need to loosen the propshaft slide a bit - remember to pre-load the centre bearing when you do it back up and mark all bits (tippex is fine) so if you pull out the shaft it goes back in the same way it came out (to maintain balance).
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
dark_sounds
Post Tue May 09, 2006 11:55 am
what do you mean preload the bearing??
dark_sounds
Post Tue May 09, 2006 6:08 pm
more light on this before it gets dark winkeye
dark_sounds
Post Wed May 10, 2006 11:00 am
wanna sort this out by sat! :)
Demlotcrew
Post Wed May 10, 2006 11:16 am
This is why you should only do one side at a time.
You will need to drop the exhaust and loosen the prop in the centre where the centre baring is. This will then give you enough slack to push the engne back onto the new mounts.
Andrew
dark_sounds
Post Thu May 11, 2006 12:26 am
ok cheers, gonna have a crack at this tommorow!
dark_sounds
Post Thu May 11, 2006 5:20 pm
got it back on the mounts and the mounts are nice and loose,
however, the engine still not budging,,
havnt released the propshaft slider, its got the covering over and exhaust preventing this from coming off....
is there any other way of allowing the engine to move around back and forth??
Post Thu May 11, 2006 7:07 pm
Cover can be got off without removing exhaust.
calder
Post Thu May 11, 2006 9:42 pm
you need to undo the gear box mountings, these are holding the engine in place at the rear
calder
