Where can I get them from? Would they make an improvement in handling over the m-tech kit (bearing in mind this is a 318iS not a 325).
I realise it won't be as comfortable as the standard stuff but it'll look better.
Or could coilovers be adjusted to be just as comfortable?
H&R Springs
Dom going in Karan's sport on sat at the meet, his has H&R cup kit and i would say the ride difference is no worse than m-tech, as you can still feel all the lumps and bumps with an m-tech set up
Karan
u can also corner at pant wetting speed with the cup kit
jimbob had the 325i sport h and r cup kit on his 318is, and reported no probs and awesome handling so just get that kit,,its also pretty cheap for a full quality kit!!
Karan
Karan
Dom
sounds good, where from?
will do a google but if people want to suggest feel free!
Karan
contact jimbob318is or e30adam-they will know
my car came with it on
Karan
Karan
Jimbob
http://www.mikestokes.com local boyracer outfit but only about 2 miles down the road so it made life a lot easier.
http://www.motorsportworld.co.uk a scottish outfit but the only online supplier I can find.
It rocks.
It rocks.
Geeman
http://www.needforspeed.co.uk handle H&R as well, but they're in Glasgow...
Scotland takes the monopoly in the H&R stakes...
what does anyone know of the H&R height adjustable kit? lots of money and lowers the front by 30-70mm!
and the back 60-30mm I like this set up!
jmc330i
You mean the coil overs? Someone on the 'old' zone has them and said they were the good, I think it was Dale??
Im looking at the H&R height adjustable kit and the KW height and damping adjustable kit, it is a lot of money but I would like the set up too.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
I would like the fact you could have your car lower than a whore's nickers when you want! And then for everyday driving have it so you can got over speed humps and park up kerbs and not worry about losing the middle silencer!
Geeman
Beware...
I've got FK coilovers on mine... supposed to lower between 30-85mm - Great! I thought...
Back only went as low as 50mm, and the front you can't really get any lower than 60mm as the inside of the tyres on standard BBS's rub on the spring, and the top of the inner arch under braking...
Research it thoroughly...
Giles.
Giles.
