Electric convertible roof
chu346
Post Mon Apr 24, 2006 8:40 pm
:woohoo: I got the electric roof working :woohoo:
Now I need to fine tune it. When the back of the roof (above the lid) lifts up it moves slowly and sometimes needs a helping hand. I have put some lubrication on all the joints I can see. Also it does move far enough forward to let the flap move up freely, but if you release the button then press it again it will then move far enough to let the flap past :screwy: . Finally, like most roofs it doesn't fold away perfectly into it's place and sometimes the flap sticks up be as much as five inches.
If you've any advise please let me know
Cheers.
DaveD
E30Zone Wiki Specialist
Post Mon Apr 24, 2006 11:44 pm
it sounds as though it needs synchronising but i left mine to a profesional ...i did have instructions which i will post when i can find them
try this site
http://www.e30ic.com/powertop.htm
and this
http://c-24-60-57-160.hsd1.ma.comcast.n ... /index.htm
martin325sport
Post Tue Apr 25, 2006 12:45 pm
I also have my roof working, but only to lift the rear hoop. the lid doesnt then move, an when you take your finger off the button you hear a click (also when you press the button again). if you can dig out the info you have I would also be very gratefull. Nick Thompson sugested I try to get it working myself before I go back to him in sheffield.
Martin
DaveD
Post Tue Apr 25, 2006 1:39 pm
if you pm me an email address i have bit more on a pdf file but as i said ...i left it to nick
chu346
Post Tue Apr 25, 2006 9:07 pm
Thanks dave, I did find that about a year ago and that was what inspired me to fix it myself, but with you making that post I did read the link again and worked some of the problem out..... If you look and read where this website talks about the bug http://www.e30ic.com/powertop.htm the arm which moves too far doesn't move enough and means that I need to activate the bug at the right point to move the hood enough for the flap to move. I think I will keep it like that to save the motor from breaking.
martin First check the motor is plugged in, then take the plug out the motor and use + and - from the battery to check if the motor works then have a read though the website above, then get back to us if you have anymore problems.
I think that the roof is quite a simple system really.
DaveD
Post Wed Apr 26, 2006 12:08 am
as i said i have another on pdf which i can mail..this is the bmw repair instructions...you need a special tool but it might help
martin325sport
Post Wed Apr 26, 2006 5:18 pm
dave D - pm sent
Chu346 - thanks, will keep you informed. I already have a link to that site from Dave D.
cheers
