Removeing trumpet from inside standard airbox with pic's
E30WEZ
Post Sun Mar 06, 2005 1:27 pm
On most of the bikes i have built you remove the trumpet for better airflow as it is only there to dull the intake sound.Just wonder if the same would work for the airbox on the E30 easy to change back as it just clips in.
WEZ
Simon
Post Sun Mar 06, 2005 1:28 pm
IIRC it's been tried and tested by someone on here, and it showed power loss!
E30WEZ
Post Sun Mar 06, 2005 1:29 pm
Ok thanks Simon i will leave it alone :D
WEZ
Ant
Retired Team Member
Retired Team Member
Post Sun Mar 06, 2005 1:35 pm
thats was me :lol:
the trumpet presents the flow to the AFM in a smooth and turbulence free fashion, thats the main reason cone kits loose torque on the e30s
Try it dude,interested to hear other opinions on this,maybe it was just my car ?
E30WEZ
Post Sun Mar 06, 2005 2:08 pm
Thinking about it now Ant could be right i have seen this somewere before about the flow to the afm having to be smooth.Plus i like my torque :D
WEZ
AlpineCab
Post Sun Mar 06, 2005 5:55 pm
I tried this when I had a K&N cone. I went back to standard airbox set-up.
I found the engine idled a lot better and ran better with the standard set up.
Toby_Unna
Boost Junkie
Post Sun Mar 06, 2005 9:03 pm
my experience is only with m30 2.8 and 3.5 engines, but i've always had good results using cone filters. i've not dyno'd any of my bmws but always though they felt quicker with a cone on instead of the airbox. i also though that the k&n replacement panel filter i bought for my 528i made zero difference and i sold it!
a friend bought an expensive cone setup for his integra type R and made an airbox and feed for it, and this surprised a dyno operator with the gain it made. but that has no afm i guess.
just my 2p worth!
E30WEZ
Post Sun Mar 06, 2005 9:27 pm
ant wrote:thats was me :lol:
Tried it fitted and not this afternoon and it's not just your car mate felt shit with it taken out.
WEZ
Post Sun Mar 06, 2005 9:33 pm
just changed my air filter and can't recal seeing that..........
Do they come off and get lobbed when serviced etc?!
Simon
Post Sun Mar 06, 2005 9:35 pm
Simon13 wrote:just changed my air filter and can't recal seeing that..........
You won't see it mind unless you remove the top half of the airbox..
Post Sun Mar 06, 2005 9:40 pm
i'll get me coat
