AUTO-MANUAL GEARBOX CONVERSION
bennyboy
Post Sat Apr 15, 2006 10:44 am
does anybody know what is involved in a auto to manual gearbox coversion on a 325i? is it just the box and flywheel or are there electrics involved? cheers!
16V IS engine!!!
Post Sat Apr 15, 2006 11:01 am
Only electrics involved are removing the starter inhibit (disconnect two plugs from existing wiring, and plug together), and adding the little loom from the gear lever to the reverse light switch.
Some people say swap the ECU as well, but I've never had any probs withe the original.
PS:If you just change the box and flywheel, you'll find your prop is several inches short, and there's nothing under your left foot.
bennyboy
Post Sat Apr 15, 2006 11:18 am
cheers. i have a 318i but im looking for a 325i donor car. i have seen a few but most are auto. just trying to find out what other parts i would need.
16V IS engine!!!
smithy318i
Post Sat Apr 15, 2006 12:27 pm
bennyboy wrote:i have a 318i but im looking for a 325i donor car.
I assume you plan on transplanting the whole engine?
its a shame you dont want a 318i manual box :cry: (coz i got one of them)
udo
Post Sat Apr 15, 2006 2:03 pm
I did this conversion on a 318, other issues to consider. You can unbolt the pedal box from a manual car in the breakers in 1/2 hour £10 max, You will need the flywheel/spigot bearing, because the auto has a torque converter. You will need the propshaft of the 2.5 manual. The front springs on the auto are harder for the heavier transmision so you will need manual springs up front. And lastly the full clutch system pedal, master cylinder (get that with the pedal box) reservior, pipes, slave cylinder, pressure plate,drive plate,thrust bearing...done. I got a deal from my regular breakers at £100 for everthing, me doing the stripping. As it turns out I have a gearbox for a six pot and slave :)
superted
Post Sat May 06, 2006 7:44 am
IM DOING THIS CONVERSION AS WELL AT THE MO - WILL 320 PROP, FLY WHEEL AND BOX DO OR DOES IT HAVE TO BE 325 STUFF?
Post Sat May 06, 2006 9:38 am
superted wrote:IM DOING THIS CONVERSION AS WELL AT THE MO - WILL 320 PROP, FLY WHEEL AND BOX DO OR DOES IT HAVE TO BE 325 STUFF?
320 stuff can be used in place of 325, but is supposed to be slightly weaker.
Lose the caps lock, please!
superted
Post Sat May 06, 2006 11:11 pm
caps lock gone :D 320 stuff it is then cheers :mad:
