Stealth
Post
Sat Apr 08, 2006 3:12 pm
Also, how much and is it easy to replace..
Or.. is there something missing..??
stevetigger
Post
Sat Apr 08, 2006 3:15 pm
Any more photo's, cant really tell where in the engine bay it is?
Stealth
Post
Sat Apr 08, 2006 3:16 pm
I'm looking up from underneath and the oil filter goes into it..
stevetigger
Stealth
Post
Sat Apr 08, 2006 3:21 pm
Cheers Steve, Nice one, Looks expensive. unless it's just a gasket..!! Looks like there is an end cap missing in my photo..!??
Fingers crossed..?? Might ask my local garage to get it up in the air for a look.!!
Stealth
Post
Sat Apr 08, 2006 3:26 pm
Steve,
Do you know if you your oil filter head looks the same as the picture from your old engine..? I'm sure there is a cap missing.!!
stevetigger
Post
Sat Apr 08, 2006 3:29 pm
Just buy number 7 from your local BMW dealer! If its $9 on the OEM then it will probably be about a £5 here!
It could just need a new gasket if nothing is missing.
I cant check mine, I have no photo's of my old engine
Stealth
Post
Sat Apr 08, 2006 3:38 pm
Cheers mate will do..!!
Thanks for the help..!!
GDBN
Post
Sat Apr 08, 2006 3:57 pm
It is a fairly easy fix... BMW actually make a repair kit for it as the original gasket was made from the wrong material. Kit is just a new gasket and ring to hold it in place. Here is the fitting guide ...
http://e30.bmwdiy.info/oil-leak/index.html
Hope it helps ... I lost patience a couple of times trying to fit it back together !!
G
Stealth
Post
Sat Apr 08, 2006 4:00 pm
Mny thanks chap... looks like I have found the answer, and with the help of you and Steve, i'm on the road to a nice cheap fix.
Top draw fellas..!!
I bow down to your techincal know-how..!!
stevetigger
Post
Sat Apr 08, 2006 5:00 pm
No worries, tis what the zone is for!
Hope to meet you soon at a meet
Stealth
Post
Sat Apr 08, 2006 5:01 pm
Yeah, Can't wait.. always nice to meet in person..!!
Again, Many thanks for the technical help, off to the stealers on Monday..!!
Adammcf
Post
Sat Apr 08, 2006 5:52 pm
Yeah those little seals are common for leaking. I changed mine when it was off and it only cost a few quid. Its a pain in the ass trying to hold it in place though to fit the circlip as the spring keeps trying to push it back out.
Widge
Post
Sat Apr 08, 2006 5:58 pm
There was actually a product recall on this and the reservoir caps in the early ninties. As you can imagine if the seal went it would dump the oil pretty quickley. You can tell if it has been changed from the original one as the new circlips have the ends pointing in to the center, to make them easier to take out.
Ant
- Retired Team Member
Post
waterpump pliers and a deep socket are the tools of choice for this little fekker BTW, dont forget to lubricate the O ring with a bit of clean oil.
the "kit" will include a new cap with a higher preload for the spring, last setup I bought was under £4
Email FTW
Stealth
Post
Sat Apr 08, 2006 6:57 pm
Sounds "fiddley".. I will bear this in mind.
Thanks for all the tips guys.. much appriciated
stevetigger
Post
Sat Apr 08, 2006 7:43 pm
Best tech help Ive seen in a while, No conflicting posts and all posts very useful!
Top work Zoners!
jamesc
Post
Sat Apr 08, 2006 9:01 pm
I bought the bits to do this the other week from the dealers and it was about 5 quid.
James
Widge
Post
Sat Apr 08, 2006 9:40 pm
I've got the kit for this kicking around in my boot. Bought it 12 months ago and now I have sold the car that leaks
