M20b25 sumps e30/e34
abelai
Post Wed Mar 29, 2006 5:47 pm
Hi I am replacing my sump on my 325i sport due to stripped plug threads.
On ETK the sump from an E30 m20b25 has a different part number to that of the E34 m20b25 sump but can they be interchanged a quick responce would be helpful. They look the same but will it clear the steering rack the same????
Post Wed Mar 29, 2006 6:40 pm
Different part No = Different part :wink:
abelai
Post Wed Mar 29, 2006 7:27 pm
yeap I think your right as the camcovers have same number and so do the dip sticks...... BUGGER :cry:
calder
Post Thu Mar 30, 2006 10:02 pm
try retapping the thread?
calder
Post Thu Mar 30, 2006 10:14 pm
calder wrote:try retapping the thread?
yeah, you can get oversize plugs
depends whether any of it has broken away though like my old 325 sump. :(
m-dtech
Unapproved Trader caution
Post Thu Mar 30, 2006 10:30 pm
the sump will fit though.
abelai
Post Fri Mar 31, 2006 12:04 am
Well from what I've heard the e34 doesn't work because the m20 sump had to be different for the rack to fit infront which it still only just does.
So I will either Helicoil the sump plug or over bore the hole but that would mean taking it to a M14!!!!! which is bloody monsterous for a sump plug and might be too big to even be done. The damn helicoil kit is £40!!!!
If I can't fix it I'll f**k it up so bad nobody can!!
