S50 convertors - Fan and Induction
bigpimpin
Hi, can I ask what electric fans and induction kits eveyone has used in this conversion?
Cheers.
Cheers.
bigpimpin
anyone ?
ian332isport
Sandy,
I initially used a 14" Pacet cooling fan, but later changed this for a regular E30 electric fan (also 14") when I installed the Aircon. If anything, the E30 fan keeps the engine that little bit cooler because I wired it for the two speed operation. The Pacet was only single speed.
As for the air filter. I initially used a foam Pipercross cone filter clamped on the end of the MAF unit. This was later swapped for a larger K&N cone. I still need to shield the filter or box it in, but there's not a lot of space. It seems to go very well without it, so it's not particularly high on my list of things to do. I do have a couple of spare intake plenums that I'm going to experiment with though. I was planning to do something a bit like the E46 M3 CSL with a flat panel filter built into the plenum.
Ian.
Ian.
buster
i wonder if an e46 airbox would fit and give any clearance advantages ?
That carbon airbox i have on at the mo has been a complete pain in the arse to fit.
I still cant get the MAF in as theres no room,if i move the abs pump back a bit it may go in but then there will be no room for a filter.I am seriously considering removing it and putting the standard one back on.
Very expensive mistake if i have to.
I have also got hold of an e30 electric fan (14")
Have yet to fit and wire it.
ian332isport
Sandy,
The fan looks fine (same as the one found on A/C equipped cars, although you would need the mounting brackets).
For the filter, I wouldn't bother buying the complete kit. You just need the filter element. I'll have a look in the garage tonight and get the K&N part number. I'm pretty sure it was £60 or £70 on it's own.
Cheers,
Ian.
Has anybody got a gen BMW airbox in with the ABS pump where it is?
I remember Brian saying something about an E34 M30 box???
I really dont want to use a cone unless I have to
Anybody?
Ive got an M50 in mine and really dont want to use a cone unless i have to
ian332isport
It's in German, but you get the general idea if you run it through a translator.
http://www.behindmatrix.com/e30/fotost/ ... f01130.htm
Ian.
Ian.
Thanks for that Ian,
looks like its going to be a tight squeeze then
Sooty
It may sound daft
but how can I get the link through a translator?
Never had to do it before.
Iain S
Iain S
Dan318-is
dude, what is left to do on your car? please inform me!ian332isport wrote:Sandy,
For the translation put the link address into this:- http://world.altavista.com/
Sooty
Cheers DanThe
Andy335Touring
Thanks Ian, thats helped me as i didn't think the M30 air box would fit that side of the bay with an ABS equiped E30.
It's for this twin 60mm TB i am hoping to graft on to the wrong side of my inlet manifold.
Toby_Unna
- Boost Junkie
that's looking pretty sweet Andy.
decided if you're welding or bolting yet?
Whats it off?
Andy335Touring
........ i just need to find an 90 degree elbow thats 100mm I/D at the air box end and i think it's 115-120mm I/D to fit over the TB ????
May be i could just chop the air box out let off and replace it with an opening the same size as the TB, if you know what i mean
stevetigger
What dimensions is the E30 electric fan?
Andy335Touring
A US Ford V8 of some sort ?DanThe wrote:Now thats what you call a Big Bore Throttle Body upgrade
Whats it off?
Andy335Touring
I'm going to have the flat side of the manifold milled(?) flat like yours and have the adapter plate welded to the manifold, then drill/tap the plate for some studs to fasten the TB to the plate.Toby_Unna wrote:that's looking pretty sweet Andy.![]()
Andy335Touring
Sorry for taking this thread O/T
stevetigger
Damn right to be sorry too, but keep up the good work!Andy335Touring wrote:Sorry for taking this thread O/T
Its always nice to see you taking the 3.5 to the next level.
oops, sorry too
Toby_Unna
- Boost Junkie
sounds like a plan. manifold is a bit thin to tap really, ok for my standard TB but that one's pretty big!Andy335Touring wrote:I'm going to have the flat side of the manifold milled(?) flat like yours and have the adapter plate welded to the manifold, then drill/tap the plate for some studs to fasten the TB to the plate.Toby_Unna wrote:that's looking pretty sweet Andy.![]()
Andy335Touring
I'd have tapped the manifold like yours but i need that plate to space the TB away from the manifold otherwise the the throttle mechanism on the TB catches the manifold, it's never as straight forward as you think when you start doing these sort of things to your motorToby_Unna wrote:
glenn
- Engine Transplant Services
WOW!!!Andy335Touring wrote:I'm going to have the flat side of the manifold milled(?) flat like yours and have the adapter plate welded to the manifold, then drill/tap the plate for some studs to fasten the TB to the plate.Toby_Unna wrote:that's looking pretty sweet Andy.![]()
that looks sweet andy.
Andy335Touring
Cheers, just got to hope i get some decent gains from it ?glenn wrote: WOW!!!![]()
Toby_Unna
- Boost Junkie
tell me about it, have you seen the throttle cable routing on mine?Andy335Touring wrote:I'd have tapped the manifold like yours but i need that plate to space the TB away from the manifold otherwise the the throttle mechanism on the TB catches the manifold, it's never as straight forward as you think when you start doing these sort of things to your motorToby_Unna wrote:
sounds like a plan. manifold is a bit thin to tap really, ok for my standard TB but that one's pretty big!![]()
lucky they left a few mm between the intake runners!
Andy335Touring
Thats how they routed it on the B10 bi-turbo i think ?Toby_Unna wrote:Andy335Touring wrote:
tell me about it, have you seen the throttle cable routing on mine?![]()
Talking of which..............
Toby_Unna
- Boost Junkie
wow
sorry for the O/T everyone!
stevetigger
No worrys, lost my post in all this O/T but its all great fun!stevetigger wrote:What dimensions is the E30 electric fan?
Andy335Touring
Read the 3rd and 4th posts in this thread mate, 14 inchesstevetigger wrote:No worrys, lost my post in all this O/T but its all great fun!stevetigger wrote:What dimensions is the E30 electric fan?
Last edited by Andy335Touring on Sat Apr 01, 2006 11:24 pm, edited 1 time in total.
Andy335Touring
erm............pass ?stevetigger wrote:cool, how deep?
bigpimpin
Dunno but it must fit in front of an E30 radiator cause it came as an option.stevetigger wrote:cool, how deep?
Nobody got one of these on a breaker ????
