However it overheats like a kettle!
It overheats all the time, makes rather a nice steamy water foutain when you take the expansion cap off! Its so bad that it eventually stalls!
I have replaced the water pump and thermostate, but still the same.
It doesn't blow hot air and gets all steamed up inside.
So I think its a heater valve messed up which is probably caused the head gasket to go
Is there a way to jam open the heater valve? Sure i've read somewhere that you can break it so it open?
Anyone fancy helping me do a headgasket job in manchester?
Thanks for any help guys...
