Spluttering
georob
Post Sat Mar 11, 2006 3:17 pm
My 89 320 has started spluttering when you accelerate and sounds like its running rough.
Could this possibly be related to me starting to use sainsburys super unleaded?
checked the filters, pipes etc, all clear
Anyone any idea?
georob
Post Sat Mar 11, 2006 3:22 pm
just checked the spark plugs, they seem very sooty
would resetting the ecu help this problem at all?
if so, how do i go about resetting it?
thanks
kam-325i
Post Sat Mar 11, 2006 3:34 pm
Does the car do it when hot or cold (Engine) ?
georob
Post Sat Mar 11, 2006 3:36 pm
does it both kam
kam-325i
Post Sat Mar 11, 2006 3:41 pm
Sooty spark plugs indicate overfueling.......have you had a look at the blue temp sensor on the thermo housing, it could be that causing the problem...or maybe a dodgy FPR....
georob
Post Sat Mar 11, 2006 4:17 pm
how would i check the sensor kam?
kam-325i
Post Sat Mar 11, 2006 4:18 pm
georob wrote:how would i check the sensor kam?
You need to measure the resistance of the senor on a cold and then a warm engine. Brianmoore will be be able to tell you the values.
georob
Post Sat Mar 11, 2006 7:45 pm
one thing i noticed is when im sitting and change through the obc kmh/ mph settings, on the mpg when i reset it, it shows 27.4 then drops to 9.4, it does this every time
does that shed any more light on my prob?
georob
Post Sun Mar 12, 2006 12:41 pm
bump
Post Sun Mar 12, 2006 1:59 pm
None whatsoever!
Blue temp sensor:
cold: 3910 ohms
cold water from tap: 3400 ohms
hot water from tap: 980 ohms
very hot water 306 ohms.
These were actual values measured from a good sensor. The faulty oone it replaced gave each reading about double.
georob
Post Sun Mar 12, 2006 2:01 pm
thanks brian
will check it out when the snow subsides a bit
