My 89 320 has started spluttering when you accelerate and sounds like its running rough.
Could this possibly be related to me starting to use sainsburys super unleaded?
checked the filters, pipes etc, all clear
Anyone any idea?
Spluttering
georob
just checked the spark plugs, they seem very sooty
would resetting the ecu help this problem at all?
if so, how do i go about resetting it?
thanks
thanks
kam-325i
Does the car do it when hot or cold (Engine) ?
georob
does it both kam
kam-325i
Sooty spark plugs indicate overfueling.......have you had a look at the blue temp sensor on the thermo housing, it could be that causing the problem...or maybe a dodgy FPR....
georob
how would i check the sensor kam?
kam-325i
You need to measure the resistance of the senor on a cold and then a warm engine. Brianmoore will be be able to tell you the values.georob wrote:how would i check the sensor kam?
georob
one thing i noticed is when im sitting and change through the obc kmh/ mph settings, on the mpg when i reset it, it shows 27.4 then drops to 9.4, it does this every time
does that shed any more light on my prob?
georob
bump
Blue temp sensor:
cold: 3910 ohms
cold water from tap: 3400 ohms
hot water from tap: 980 ohms
very hot water 306 ohms.
These were actual values measured from a good sensor. The faulty oone it replaced gave each reading about double.
georob
thanks brian
will check it out when the snow subsides a bit
