Oil breather filter
braincat
Post Sun Feb 26, 2006 8:32 pm
I'm about to undertake a BBTB conversion, and as I'm removing the inlet manifold, the breather tube is obviously viewable. When he heard this one of my friends said I should fit a filter to it. Is there really any point or gain to be had with this?
daveyw
Post Sun Feb 26, 2006 8:38 pm
a mechanic mate of mine has one fitted to his capri turbo and says they don't do a thing apart from look nice under the bonnet
braincat
Post Sun Feb 26, 2006 8:39 pm
Thought as much!
Geoff
Post Sun Feb 26, 2006 11:14 pm
Quick question, why are you removing the inlet manifold just to replace the throttle body with a big bore version?
Un do all the necessary anciliaries thats attached to the original TB then its just 4 nuts and you can remove the throttle body.
No need to remove the inlet manifold at all.
trit21
Post Mon Feb 27, 2006 12:11 am
had one on my r33 skyline under pressure it spat oil out and caught alight
