obc illumination
cortina
Post Sun Feb 26, 2006 8:48 pm
my buttons willnot light up on my 13 button obc when the lights are switched on.is there a bulb gone?how do you replace it?
bottlecapE30
Post Sun Feb 26, 2006 8:52 pm
does the screen light up if not that is a replaceable bulb
smithy318i
Post Sun Feb 26, 2006 8:58 pm
Hello again... And welcome BTW.
there is a small twist out bulb in the back of the unit to illuminate the buttons.
cortina
Post Sun Feb 26, 2006 9:04 pm
how do you get to the bulb?how do you remove the obc?where do i get a bulb from?
smithy318i
Post Sun Feb 26, 2006 9:09 pm
cortina wrote:how do you get to the bulb?how do you remove the obc?where do i get a bulb from?
to get to the bulb, you need to remove the OBC.
to remove the obc you need to:
remove the radio
remove the switch above the radio
open the glovebox and remove the plastic cover on the right.
now get a small screwdriver into the rear of the OBC and unscrew it from the back.
Post Sun Feb 26, 2006 9:21 pm
You can remove the the bulb that lights the buttons by removing the side access panel in the glovebox and reaching in behind, or if you've got a small hand, through the radio hole.
It's the OBC display backlight that you have to remove the unit for.
cortina
Post Sun Feb 26, 2006 9:31 pm
mine is m3 lhd.hand is too big to get thro radio opening.will investigate the way in via the glove box.thanks
TheDutch
Post Mon Feb 27, 2006 1:55 am
Hmm whereabouts on the OBC is this? Is it just one bulb for the buttons? I assume the bulb is a bit like one of the instrument cluster bulbs which are easily replaceable.
Post Mon Feb 27, 2006 9:01 am
Not sure if it's identical to the cluster ones, but it's very similar at least.
It projects out of the back of the OBC, just about in the centre.
