ARRGH!central Locking is fooked:-(
320Touring
Post Mon Feb 28, 2005 2:19 pm
Went out to my car last night to start it up (waiting on me getting cash to tax it)
Put key in drivers door and turned.....
only drivers door opened-although heard the whine from the actuator in the footwell...
NONE OF THE OTHER DOORS OPEN (including the FUEL filler :cry: )
tried operating it from the boot lock but got no response (apart from an open boot)
Key wont open the passengers side even though i made sure double lock is off.
Anyone got any ideas how to get the other doors open seperatly, and how to open the fuel cap?
I've got the zone article on overhauling the central locking, so i'll get that done at the weekend-but i need to be able to let people into my car in the meantime!
Any help would be greatly appreciated,
320Touring
Richy325iTouring
Post Mon Feb 28, 2005 2:44 pm
Had same problem on mine. Changed the actuators in the doors and the control unit in footwell and still nothing. then i changed the loom in the door and i now have central locking again.
320Touring
Post Mon Feb 28, 2005 2:53 pm
is the loom change easy to do?
will one from any e30 fit?
just a case of removing the existing wiring and slotting new one in?
thanks for help :thumb:
Karan
Post Mon Feb 28, 2005 3:44 pm
theres a multipin connector from teh door to car body, these pins tendto get rusty, u can locate the rusty pin by removing the connector anbd shove anoither pin in, this fixed the problem on my old e30
320Touring
Post Mon Feb 28, 2005 3:46 pm
cheers karan!will give it a bash when i get home!
is it in the loom running from the middle of the door (ie half way up)?
do the pins just pull out?where do i get spares?
Andy325i
Post Mon Feb 28, 2005 11:08 pm
where the Door loom plugs into the body, is there a proper tool for removing the pins from the plastic housing?
can you buy the plastic housing seperatly? (both parts)
Anyone know where you can get the pins from?
Karan
Post Mon Feb 28, 2005 11:14 pm
i beleieve ian332isport knows where to get the pins from.. send him a PM.
Andy325i
Post Mon Feb 28, 2005 11:51 pm
cool cheers karan will do :D
Post Tue Mar 01, 2005 12:01 am
First of all, find the two red/black wires that go to back of the socket in the driver's door pillar. (access behind speaker in footwell). Disconnect both of them and join them together. This will cure most central locking problems.
If you still have faulty connections in the door plug/socket, it is possible to feed a new wire from inside the door, through the hole in the plug and socket, to bypass the pins completely.
johnono
Post Tue Mar 01, 2005 12:03 am
thats what ima gonna do :cool:
320Touring
Post Tue Mar 01, 2005 8:05 am
cheers guys!help is much appreciated! :cool: :thumb:
will give the red/black wire thing a go when i get home from work, as the mrs is demanding to be run about in the car 8O
I'll let you know what happens!
320Touring
Andy325i
Post Tue Mar 01, 2005 7:08 pm
Brianmoooore wrote:First of all, find the two red/black wires that go to back of the socket in the driver's door pillar. (access behind speaker in footwell). Disconnect both of them and join them together. This will cure most central locking problems.
What to the red/black wires do then? Do they tell the locking modual that the door(catch) is shut?
Post Tue Mar 01, 2005 7:36 pm
No, it's the power feed to the central locking ECU. Goes into the door, round a little loop of wire and comes out again.
320Touring
Post Tue Mar 01, 2005 7:40 pm
so by cutting and joining them you remove the power supply to the control box?
if so then how do you get it to work again?
cheeers
320touring
Post Tue Mar 01, 2005 7:49 pm
No, the control box is below the right hand footwell speaker. The power just goes into the door and straight out again. Not used inside the door on any E30 I've dealt with.
320Touring
Post Tue Mar 01, 2005 10:07 pm
oops !may have cut wrong ones :cry:
there are two red/black ones that feed into the control box-i cut them!
suppose i'll need to connect them back up again?
so its the two red and black ones that go to the door that i cut?are they the same wires?
thanks brian
320Touring
Treeman612
Post Sun Mar 13, 2005 7:27 pm
:D Hi, had exactly same problem on my 1989 320i - took out the central locking control unit from under the drivers side speaker, took it apart as per the advice in 'Articles', and, lo and behold, the fuseable link inside had unsoldered itself. Re-soldered link back together, and all c/l now works. Guess I should check out wot made it break, maybe just hard work operating the actuators in cold/damp weather overloaded it?
Seems ok for last week though. treeman612
320Touring
Post Mon Mar 14, 2005 11:11 am
Hey Peeps, thanks for all the advice :thumb:
got an auto electrician to have a look at it-He managed to pop all the deadlocks so I can lock/unlock the doors manually!
This suits me fine as saves money trying to find the exact fault.
Now gotta get the cent locking loom out and the motors too-save me some weight!!
320Touring
Treeman612
Post Wed Mar 16, 2005 1:46 am
good solution to yr prob, but I think immbiiser good idea - original could be improved, get some good software & MK is scrummy.....
Treeman612
Post Wed Mar 16, 2005 1:51 am
ps - weight? - I worked today next to an ndependent lotus seven dealer/builder & he built a 7 @ 390kg with a fireblade mill @ 150BHP weighing 38KG inc g/box - n yr worried abt weight???
Treeman612
Post Wed Mar 16, 2005 1:56 am
pps he said you could hit roundabouts pulling 9.6 gee's in this thing, & still go round.......was he exaggerating?
320Touring
Post Wed Mar 16, 2005 1:19 pm
Treeman612 wrote:pps he said you could hit roundabouts pulling 9.6 gee's in this thing, & still go round.......was he exaggerating?
9.6 G?!
the dodge viper only can pull 0.91 lateral g......
your guess as to whether the figure is correct?!
with regards to weight, i'm toying with the idea of lightening my touring as much as possible, so as to improve its resposivness see
http://www.e30zone.co.uk/modules.php?na ... highlight=
for more details!
thanks once again for your help with the central locking!
320Touring
MarkP
Post Fri Mar 18, 2005 12:07 am
If a cars central locking is broken would fitting an alarm that has a fob button for opening/locking doors work fine or does the central locking have to be working for the alarm to lock/open the doors?
