reconditioned LSD...
dark_sounds
Post Mon Feb 20, 2006 10:11 pm
hi all... just wondering how much does it cost to recondition a LSD?? does it vary depending on the ratio?? cheers
zaust
Zone day release
Post Tue Feb 21, 2006 1:34 pm
300-500
M30 Tech 1 Touring on gas.
ianeire
Post Wed Feb 22, 2006 11:56 pm
Find someone that does OPEL diffs and let them do it for half nothing. The diffs use the same ZF plates. A lot cheaper gotten than off BMW.
1990 Brilliantred 325i Sport
www.e30owners.com Irish e30
Widge
Post Wed Feb 22, 2006 11:59 pm
ianeire wrote:Find someone that does OPEL diffs
So much easier said than done!
Dan318-is
Post Thu Feb 23, 2006 12:01 am
I take it by opel he means vauxhall??
How much do they charge then?
Davenotouring
Post Thu Feb 23, 2006 12:02 am
I'll see if I can get any contacts through work....
BMW 328i Cab - Daily Slag
dark_sounds
Post Thu Feb 23, 2006 12:03 am
hmm interesting, i mean having a "like new" LSD would be quite nice,, no whine, and u know its gonna be pretty much faultless :)
ianeire
Post Thu Feb 23, 2006 12:07 am
Sorry, Vauxhall, OPEL in ireland. I was priced about 450euro for a rebuild to standard BMW 25% spec using BMW parts. I got a 40% rebuild from an OPEL man, using identical plates for the same price, 450. He would have done the rebuild the BMW spec for 250 euro.
He needed to take the car for a few days to do it as the diff casing has to be machined slightly to fit two extra clutch packs in for the 40% build.
Good and tight, good fun.
Anyone that does rally preping etc would be able for it not a bother.
OllieB
To be honest mate, I wouldn't worry about a bit of whine from your diff. When it starts to do that you know you can still have another 200,000 miles out of it so it is not really a problem is it?
I'm too scared to drift properly......
jaistanley
Post Thu Feb 23, 2006 5:28 pm
The diff I have is either VERY low mileage or a re-build and whines a tiny bit on over-run. This is probably due to the denser Z Coupé bush and poly subframe bushes though.. I doubt you'd come near to hearing it without them.
Mines a 4.1 which is perfect for the 318is. Comes from an American spec M3.
Will be selling it in coming months..
Jai
Dan318-is
Post Thu Feb 23, 2006 5:52 pm
I have a small case 4.1 slipper on my Is an it whines like a fookin doggie when cold. the pitch gets higher and higher and then randomly stops; after about a mile there is no whine at all until i do donuts etc and make it lock up, then it whines faintly?
Does this merrit a rebuild or is it the usual differentail characteristsics of an e30?
OllieB
Post Thu Feb 23, 2006 8:00 pm
These diffs are effectively bullet proof, I say wait until it goes bang. Same goes for the Getrag gearboxes, they go forever....
Jimbob
Post Thu Feb 23, 2006 8:03 pm
OllieB wrote:These diffs are effectively bullet proof, I say wait until it goes bang.
Until it does go bang at 60mph on a duel carriageway. Then you'd think why didn't I just get it done...
Post Thu Feb 23, 2006 8:48 pm
318-is wrote:I have a small case 4.1 slipper on my Is an it whines like a fookin doggie when cold. the pitch gets higher and higher and then randomly stops; after about a mile there is no whine at all until i do donuts etc and make it lock up, then it whines faintly?
get that diff out before u f**k it. It's rare u won't find another and it's whining and your doing donuts with it. If it's making noises like u say, there something clearly wrong with it.
Dan318-is
Post Thu Feb 23, 2006 8:51 pm
I dont really do that many donuts dude. only the occasional flick out or sideways action when its wet. I never do it when its dry. Also, what do i put in there in the mean time? Ian said he mite be selling his 3.91 slipper soon maybe i should invest in that??
Post Thu Feb 23, 2006 8:59 pm
a small case open diff!
they are alot lighter than large case! Scrappy etc to find one
Demlotcrew
Post Thu Feb 23, 2006 9:00 pm
The clutch packs dont whine!
The barings on the diff have gone and any good gearbox/diff place should be able to replace those. Thing is they might be using a substandard replacement part which might not be upto the job of 200.000 miles plus.
Andrew
Dan318-is
Post Thu Feb 23, 2006 9:01 pm
If its not raining il get on to it 2moro
fancy helping me fit it? I have nevr changed a diff
could also do with a hand on the front springs but first things first ey!!
Post Thu Feb 23, 2006 9:03 pm
who do u want to help?!
Jimbob
Post Thu Feb 23, 2006 9:05 pm
Ah the joys of a diff!
When the large case 4.10lsd locked I had to have all new bearings made up by a local custom bearing firm, had them made and fitted for Ԛ£120 i think.
HTH
Post Thu Feb 23, 2006 9:08 pm
tis a very sad job to do. Not one of my personal favourites!
Demlot likes changing them :poke:
Dan318-is
Post Thu Feb 23, 2006 9:09 pm
Jimbob wrote:Ah the joys of a diff!
HTH
Thats not as bad as i thought!
Simon13 wrote:who do u want to help?!
Well your the nearest to me!
Post Thu Feb 23, 2006 9:10 pm
i don't mind if u need some help
Dan318-is
Post Thu Feb 23, 2006 9:12 pm
Will get on the case!
Got any ideas where to send it around here for new bearings (if thats what it is??)
Post Thu Feb 23, 2006 9:30 pm
these must be on the output side of things on the diff?
can someone give a price on new from BMW off the etk
my dad knows where to get bearings for good prices if thats what is up with it.
Karan had a diff rebuilt i can't think of the name of the place Neil@All gears?
Ian332 had his diff rebuilt for around Ԛ£250 if i remember correctly
dark_sounds
Post Thu Feb 23, 2006 9:48 pm
hmm,, right,,,, so a whiney diff means its most prob the bearings,,, which costs roughly 150 to sort out?
and other then this they are practically bullet proof.
i remember reading somewhere the small case and large case diffs required some adjustment to something? anyone shed any light on this?? what needs to be changed to get a small case in an orignally large case place?
cheers
Post Thu Feb 23, 2006 9:51 pm
u don't want to be fitting a small case diff to a car with a l case. It will die quite quickly
but fitting a l case to s case is ok. It's the prop that needs to be either lenghtened or shortened. I can't remember which way. U can adjust the lenght of it from the middle of it.
U still up for these smoked lights mate? Can bring on monday?
dark_sounds
Post Thu Feb 23, 2006 9:57 pm
defo mate! was about to pm you actually :)
infact gonna pm you anyway ;)
