[/img]
oguz3001 wrote:Alpina reps, azevs or bbs but 16 or 17"
In my opinion these are the main aloys that suit the e30
I have almost given up looking for Hartge's, if I dont source a set soon im going down the Borbet A route in 16", fat on rear not so fat on frontoguz3001 wrote:lol of coarse not forgettin the Hartge's if you can find um.
They are Devil H109 alloys. As an aftermarket style they were the only ones I liked and which would could be pulled off on an E30. Inspiration for choosing these wheels sounds funny but the Ferrari F430 has those similar style rims hence the choice.NH325CAB wrote:Gouki, what are those on your cabby?
I also looked at TSW, although the PCD was correct and the even an acceptable offset (though spacers can compensate for the offset) I couldn't get wheels with the correct hub size.rite its looking a lot like the alpinas at the mo but was thinking of these or am i mad?
cheers dude, i've fitted them on without spacers, and they are fine although they do sit in just a bit. I've only just bought spacers for em recently but I have to get longer bolts for those particular wheels as the nuts are of a special type. And they are 17's.NH325CAB wrote:Also, Gouki,
Are they 17's and do they require any spacing etc?
ARB kit - good idea, that's on my shopping list too, anyone else up for it? Maybe we can get a group buy discount from the Zone Shop?next up is h&r front and rear anti roll bars followed by a good suspension set up - new shocks and springs - nothing too low say 30mm max - any sugestions
garyp_E30_325i wrote:ARB kit - good idea, that's on my shopping list too, anyone else up for it? Maybe we can get a group buy discount from the Zone Shop?next up is h&r front and rear anti roll bars followed by a good suspension set up - new shocks and springs - nothing too low say 30mm max - any sugestions
Suspension kit - I've fitted the SPAX PSX kit, it's excellent, for fast road use I have her on mid settings (slightly hard but she feels absolutely solid![]()
) and I've had her on a track once, mid settings too soft but she still performed really well.
Strut braces - I don't know if you have 'em or not, front & rear uppers will cost you less than the ARB kit, are dead easy to fit and make a HUGE difference - even before I fitted the SPAX kit they made my car (325 SE) feel like night & day. I've got the Sparco double tube Aluminium on the front and single tube Al on the rear, they may not look as cool as some others but they're cost effective, readily available and do a good job. If you do go for strut braces make sure you do front & rear together and keep them matched (don't mix different makes or flex) 'cause your car is designed to flex, and front & rear should flex together (relatively), if you stiffen one e.g. by 30% and not the other you will actually upset the handling- same goes for the suspension, for good handling (which it sounds like you want, otherwise why bother with the ARB's) always keep things matched!
Sounds like you're cars gonna be a doll when you're finished(if you ever finish)
Whatever you do with her, enjoy![]()
