Help rough running car
I thought i had finished my m52 swap but today i started the car and more issues have happened ,when i start it it coughs and splutters and when i try to rev it it trys to stall and wont rev past 2000rpm,i have a very very cheap scan tool did a quickie and it showed camshaft sensor on bank a so i bought a brand new one for 140 and hoped this would be the fix, that code now doesnt come up which is great but it then brought up a fault code to injector 1 so i unplugged them all and firmly pushed them back in and that code has gone but still it made no difference to the rough running and i have no further fault codes can anybody suggest what to look for next, getting to the point i might just cut my loses
Have you ever seen/heard the engine running properly (i.e., when fitted in the donor car), prior to installing it?
https://youtube.com/shorts/lAHoqq34ZrI? ... 89HpY5eDLJ
When the car is reving up my foot is flat to floor
Perhaps try refitting the old ignition parts, if you still have them - perhaps there's a fault with the new ones...
I saw this on an E39 forum:
"Most probably a vac leak somewhere. Check all the pipe work on the diags below. You can try running with the MAF disconnected briefly. The car should set itself to a basic state which will at least give an indication if the MAF is at fault."
https://www.bimmerforums.co.uk/threads/ ... pm.567189/
Good work. Ideally, use a multimeter to check for the HT lead(s) resistance and injector impedance. If you're using coil packs, try swapping them over between a pair of cylinders and see if the fault gets transferred...
Perhaps try removing it, leaving it connected to the loom with some fuel feed and place it to spray into a jar with the engine running, to check the spray pattern (should be an even conical shape).
I would stick to standard injectors unless the engine's heavily modified.
I had problems with the injectors on my M54 after it was standing a while. Eventually they came round but not until a good few taps with the thick end of a screwdriver to free them up. Standing, bad fuel and ethanol in 95 do injectors no favours.
Not lost on me that the M20 started on the key and ran well after standing same amount of time.
No, you can try just tapping them in situ from above - do this before attempting to remove any. With a bit of luck, it will unseize itself and once the fuel starts flowing, it should clean itself.
As Speedtouch said, I just got a bit frustrated after swapping things around, I got it running on 5 (after starting on 2) but the last one wouldn't free. I gave the top of the rail over the injector a good 'tap' with what I had in my hand at the time (luckily it was a softish handled screwdriver) and it sprang to life.
Worth a try
Worth a try
Right my troubles have returned same issues bad running trys stalling when reved and back firing onto intake i have done a smoke test today and had a leak qhich is fixed but still running shite,i am just waiting for fuel pressure tester recommend by dan but does anybody else have an suggestions before i give ip and sell it
Have you tried doing a compression test to ensure you're getting good even figures across all cylinders?
How did you get on with that?
So my fuel pressure is about 3.2bar when running,today i took off my disa ,my throttle bodyand icv all seems ok so i put it all back together and now it work again ,i have not taken her for a drive yet but this is defo a head scratcher and the trouble is i jave lost all faith in her as i have no idea what caused this and if it will come back
Oh well, sounds like you've at least made progress with it. I would be inclined to take it for an "Italian tune-up" to blast the cobwebs out!
Defective throttle body, perhaps?
"A P0220 code on a BMW E39 2.8 (M52TU engine) indicates a Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction. Because the E39 uses an electronic drive-by-wire system, this code typically points to a discrepancy between the throttle body position and the accelerator pedal demand, usually resulting in "limp mode" (reduced power, poor throttle response, stalling)".
It's nevertheless worth checking all the electrical connectors have clean terminals (use contact cleaner, if necessary), and perhaps some carb/brake/EGR cleaner down the butterfly valve if it's a bit gungy in there.
I'd say it's worth checking for good engine-to-body earthing, and have another good look at all the vacuum pipes.
Perhaps try disconnecting the battery to reset the ECU (or use a code reader to clear it) and take it out again, but park up somewhere different this time and see if it repeats the problem...
Bit of a long shot, but there have been reported instances of cars being affected by telecoms transmission masts, etc.
I have tried the battery method, i also have 2 working ecus and have tried both and both have the same issue ,i am leaning towards an electrical issue but dont have the knowledge so i have conceded defeat and have a mobile mechanic coming out monday
