Help rough running car
Corasdad
Fri Aug 22, 2025 11:40 am
I thought i had finished my m52 swap but today i started the car and more issues have happened ,when i start it it coughs and splutters and when i try to rev it it trys to stall and wont rev past 2000rpm,i have a very very cheap scan tool did a quickie and it showed camshaft sensor on bank a so i bought a brand new one for 140 and hoped this would be the fix, that code now doesnt come up which is great but it then brought up a fault code to injector 1 so i unplugged them all and firmly pushed them back in and that code has gone but still it made no difference to the rough running and i have no further fault codes can anybody suggest what to look for next, getting to the point i might just cut my loses
Fri Aug 22, 2025 2:20 pm
Have you ever seen/heard the engine running properly (i.e., when fitted in the donor car), prior to installing it?
Corasdad
Fri Aug 22, 2025 2:46 pm
Yes it run fine b4, i took it for a drive the other day to get wheels aligned.
Corasdad
Fri Aug 22, 2025 2:49 pm
https://youtube.com/shorts/lAHoqq34ZrI? ... 89HpY5eDLJ
When the car is reving up my foot is flat to floor
Corasdad
Sat Aug 23, 2025 10:46 am
Ivc cleaned and free moving still no change,its had new disa fitted new plugs new pcv fitted
Sat Aug 23, 2025 1:12 pm
Perhaps try refitting the old ignition parts, if you still have them - perhaps there's a fault with the new ones...
I saw this on an E39 forum:
"Most probably a vac leak somewhere. Check all the pipe work on the diags below. You can try running with the MAF disconnected briefly. The car should set itself to a basic state which will at least give an indication if the MAF is at fault."
https://www.bimmerforums.co.uk/threads/ ... pm.567189/
Corasdad
Sat Aug 23, 2025 2:41 pm
My car runs with no maf anyway ,every time i plug it in it stalls the car so it stays unplugged for now until i can sort rest of the gremlins
Corasdad
Sat Aug 23, 2025 2:47 pm
Found one vac leak, looks like rubber bung has come off
Corasdad
Mon Aug 25, 2025 5:38 pm
Now showing injector circuit cylinder 1 is this likely a wire or bad injector
Mon Aug 25, 2025 6:23 pm
Good work. Ideally, use a multimeter to check for the HT lead(s) resistance and injector impedance. If you're using coil packs, try swapping them over between a pair of cylinders and see if the fault gets transferred...
Corasdad
Mon Aug 25, 2025 8:18 pm
Yeah changed over 1 to 2 and the fault stayed with 1 so it must be the injector , i will get some carb cleaner and try clean it first ,if i have to buy new should i buy just one or a full set and whats recommended
Mon Aug 25, 2025 9:18 pm
Perhaps try removing it, leaving it connected to the loom with some fuel feed and place it to spray into a jar with the engine running, to check the spray pattern (should be an even conical shape).
I would stick to standard injectors unless the engine's heavily modified.
flybynite
Tue Aug 26, 2025 8:41 am
I had problems with the injectors on my M54 after it was standing a while. Eventually they came round but not until a good few taps with the thick end of a screwdriver to free them up. Standing, bad fuel and ethanol in 95 do injectors no favours.
Not lost on me that the M20 started on the key and ran well after standing same amount of time.
Corasdad
Tue Aug 26, 2025 2:16 pm
Do i take the fuel rail off to tap them is it worth spraying carb clean into it
Tue Aug 26, 2025 2:53 pm
No, you can try just tapping them in situ from above - do this before attempting to remove any. With a bit of luck, it will unseize itself and once the fuel starts flowing, it should clean itself.
flybynite
Tue Aug 26, 2025 3:06 pm
As Speedtouch said, I just got a bit frustrated after swapping things around, I got it running on 5 (after starting on 2) but the last one wouldn't free. I gave the top of the rail over the injector a good 'tap' with what I had in my hand at the time (luckily it was a softish handled screwdriver) and it sprang to life.
Worth a try :thumb:
Corasdad
Tue Mar 03, 2026 3:38 pm
Right my troubles have returned same issues bad running trys stalling when reved and back firing onto intake i have done a smoke test today and had a leak qhich is fixed but still running shite,i am just waiting for fuel pressure tester recommend by dan but does anybody else have an suggestions before i give ip and sell it
Corasdad
Wed Mar 04, 2026 9:44 pm
Can anybody confirm vemo are who make bmw crankshaft and camshaft sensors for e39 2.8.
New fuel pump and filter and regulator no difference
Thu Mar 05, 2026 11:25 pm
Have you tried doing a compression test to ensure you're getting good even figures across all cylinders?
Corasdad
Fri Mar 06, 2026 6:59 pm
No not yet, i dont think its compression but worth a try ,my fuel presser tester came today so thats saturdays job
Sat Mar 07, 2026 11:08 pm
How did you get on with that?
Corasdad
Sun Mar 08, 2026 5:37 pm
I ordered wrong one but new one has turned up today but after taking things off and putting them back on it works now no idea why, going to teat fuel pressure monday anyway
Corasdad
Mon Mar 09, 2026 3:19 pm
So my fuel pressure is about 3.2bar when running,today i took off my disa ,my throttle bodyand icv all seems ok so i put it all back together and now it work again ,i have not taken her for a drive yet but this is defo a head scratcher and the trouble is i jave lost all faith in her as i have no idea what caused this and if it will come back
Wed Mar 11, 2026 11:07 pm
Oh well, sounds like you've at least made progress with it. I would be inclined to take it for an "Italian tune-up" to blast the cobwebs out!
Corasdad
Thu Mar 12, 2026 9:06 am
Lol its on the cards but need to get wheel alignment first
Corasdad
Fri Apr 24, 2026 12:48 pm
So taken my car for spirted drive today and all was great parked up de ided to go back out and the problem is back (i hate this car now ) can anybody help,it has a code p0220
Fri Apr 24, 2026 2:22 pm
Defective throttle body, perhaps?
"A P0220 code on a BMW E39 2.8 (M52TU engine) indicates a Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction. Because the E39 uses an electronic drive-by-wire system, this code typically points to a discrepancy between the throttle body position and the accelerator pedal demand, usually resulting in "limp mode" (reduced power, poor throttle response, stalling)".
Corasdad
Fri Apr 24, 2026 2:38 pm
Mine is cable not drive by wire, throttle body looks like this
