M40b16 engine cutting on aceleration
minesapint
Tue Jan 13, 2026 9:19 pm
I’ve been chatting with my friend GPT about your problem & he suggests this……..
Given the facts now confirmed:
• BMW M40B16
• Manual
• Cuts cleanly at ~4000 rpm and above
• Also happens free-revving
• New crankshaft position sensor
• New ignition coil
There are only two realistic remaining causes on this engine. One is by far the most common.
✅ MOST LIKELY CAUSE: Ignition Power Stage (Ignition Control Module / ICM)
This is the number one cause of a hard 3.8–4.2k rpm cut on M40 engines once CPS and coil are ruled out.
Why this fits perfectly
• The ICM switches the coil at high speed
• At ~4000 rpm the switching frequency becomes high
• A failing ICM:
• Works perfectly at low RPM
• Cuts spark instantly at a repeatable RPM
• Causes a clean cut (no misfire)
• Engine immediately drops to idle and recovers
This is textbook M40 behaviour.
Key point
A bad ICM will do this even with a new CPS and new coil
Resistance tests do not reliably detect ICM failure.
How to confirm (best test)
Freeze-spray test:
1. Run engine until it cuts at 4000 rpm
2. Spray the ignition module (aluminium heat-sink unit near the coil)
3. Immediately try revving again
✔ If it now revs past 4000 → ICM is faulty
Substitution with a known good unit is the definitive test.
⚠️ SECOND POSSIBLE CAUSE (LESS COMMON): Throttle Position Switch WOT contact / wiring fault
Not “TPS worn”, but WOT contact shorting or mis-signalling.
Why it can cause this
• At high throttle angle the WOT contact closes
• If the switch or wiring shorts:
• ECU momentarily cuts fuel/ignition
• RPM collapses
• Engine falls back to idle
Quick isolation test
• Unplug the TPS
• Free-rev engine
✔ If it now revs cleanly → TPS or wiring fault
❌ If unchanged → TPS is not the issue
(Unplugging it is safe; ECU defaults.)
❌ What it is NOT (with certainty now)
❌ Fuel pump or filter (would not cut free-revving)
❌ Rev limiter
❌ ECU (extremely rare)
❌ Lambda sensor
❌ Idle valve
❌ CPS or coil (already new)
✅ Final Diagnosis Probability
Component Probability
Ignition power stage (ICM) -80–85%
TPS WOT contact / wiring -10–15%
AFM signal dropout <5%
Still trying to help.
blood69
Tue Jan 13, 2026 10:32 pm
Hi, thanks for your help.
The ICM on Bosch Motronic Systems is a transistor inside the ECU that is controled by the CPU depending on the signals from diferent sensors, mainlythe CPS sensor. It's not an external module.
I've tried 3 different ECUs already, they all work on another e30s.
About the TPS, I've tried with the TPS disconnected and still have the same issue. If I disconnect the TPS in other E30 there's no issue whatsoever other than the WOT map will not engange.
Wed Jan 14, 2026 3:18 pm
Is it possible that the ignition coil has developed a fault, even though you replaced it last year? Also worth measuring the resistance of the HT leads to ensure they're within spec.
Do you have the CID lead fitted?
https://www.e30zone.net/e30wiki/index.php?title=CID
It's also worth checking out the main engine loom connector (C101):
https://www.e30zone.net/e30wiki/index.php?title=C101
blood69
Wed Jan 14, 2026 10:17 pm
Hi, thx for your reply.
Thr CID is not fitted since 2017 on this car, and I never had any issue.
The C101 I cleaned the conector and test the CPS signal but did not test the other connections.
The Coil I've tested out with an old Bosch working coil and it does the same behavior.
Thu Jan 15, 2026 11:11 am
Hmm, new engine time, perhaps? How many miles has it done?
minesapint
Thu Jan 15, 2026 9:51 pm
Been chatting with my pal again……….
AFM failure (why it matches perfectly)
When AFM signal drops out at a certain flap angle:
• ECU suddenly “loses” load info
• Injector pulse collapses
• Spark is momentarily invalid
➡️ That causes an instant, clean cut at a specific RPM, regardless of load.
Bottom line
• Bad AFM or ECU power = hard RPM wall
Your symptom profile is classic AFM carbon track failure or DME relay voltage drop.
Now I know you’ve “swapped out” (as you say) your AFM, but are you certain the one you tried was a known good one?
Swapping out parts is not a good fault finding technique, Have you examined the track on your AFM, the pick-up arm can be moved slightly to wipe a different area of the carbon track, best way to test this is not swap but get your meter on it, chase the fault!
blood69
Thu Jan 15, 2026 10:03 pm
Bottom line
With the AFM disconected it happens the same. On other e30 I disconected the AFM and it doesn't cut.
I also tested the AFM and have smooth voltage throughout the carbon track.
blood69
Thu Jan 15, 2026 10:12 pm
There is no way to know the milage of an E30 😅
The cluster always fails. This one was busted 7 years ago but I fixed. It have now 155000 km on the cluster.
3 or 4 months ago this engine was open to change a failed headgasket. The engine was ok and strong until now.
Thu Jan 15, 2026 10:14 pm
Have you carried out a compression test?
blood69
Thu Jan 15, 2026 10:20 pm
Unfortunately I haven't. I don't have the kit. I'm gonna try next week to send the car for a repair shop. And let the guys have some fun 😂🤣😅
minesapint
Thu Jan 15, 2026 10:43 pm
You’d not mentioned about the head being off!
Asked my pal if this could be a possible cause……….
Yes — it absolutely could have, and on an M40 there are very specific ways a head-gasket job can create exactly the fault you’re seeing, even months later.
This doesn’t contradict the AFM theory either — the two can be linked.
How a head gasket job can cause a hard 4k cut on an M40
1️⃣ Engine ground strap disturbed or left marginal (VERY common)
During a head job:
• Intake off
• Engine harness moved
• Ground straps often loosened or refitted poorly
Why this matters
• ECU, AFM, and CPS share ground reference
• At higher RPM → more electrical noise → ECU loses signal → hard cut
Classic sign
• Runs perfectly until a specific RPM
• No fault codes
• Repeatable limit
What to check
• Main engine-to-chassis ground (near engine mount)
• Ground eyelets on intake manifold
• Clean to bare metal, retighten
2️⃣ AFM boot / intake leaks introduced
After head removal:
• Rubber intake boot refitted
• Small cracks missed
• Vacuum lines swapped or left loose
Why this shows up at ~4k
• At higher airflow, unmetered air overwhelms correction
• AFM signal goes out of range → fuel cut
Check carefully for:
• Split intake boot underside
• Brake booster line
• Idle control hoses
3️⃣ Timing belt installed one tooth out
This one is critical.
If the belt was installed one tooth retarded:
• Engine runs “fine”
• Revs cleanly but hits a wall around 3.5–4.5k
• No codes
• Feels like a limiter
M40 is interference
If belt age or install accuracy is unknown → verify cam timing now.
4️⃣ AFM carbon track wear accelerated
If the engine was overheated before the HG:
• AFM track often already worn
• New airflow characteristics after repair push flap into the worn zone
So the HG job didn’t “break” the AFM, but it made the failure obvious.
5️⃣ TPS misadjusted after refit (secondary effect)
Not your primary fault, but:
• If TPS never hits WOT, engine feels worse at high RPM
• Makes AFM-related issues more noticeable
What I’d check first given the HG history (in order)
1. Verify cam timing (do not skip this)
2. Clean and re-secure all engine grounds
3. Smoke test / inspect intake boot and vacuum lines
4. Unplug AFM test
5. Swap DME relay
One key question (important)
When the head gasket was done:
• Was the timing belt replaced?
• If yes — by who (DIY vs shop)?
• Any overheating before the HG failed?
Your answers will tell me whether this is an AFM/ground issue or a timing issue, and which one to chase first.
Sat Jan 17, 2026 7:54 pm
Nice summary of diagnosis! I recently had to correct the timing on my 2009 Abarth Grande Punto after a previous owner/garage fitted the cambelt one tooth out, causing the EML light to keep coming on, even though the engine ran surprisingly well - but even better after I'd corrected it.
minesapint
Wed Jan 28, 2026 12:43 am
Have you sorted it yet?
fixedwheelnut
Sun Feb 01, 2026 12:55 pm
My first thought seeing this was camshaft & follower wear, what happens is the follower wears to an 'S' shape rather than smooth curve, this makes the inlet valves oscillate in action rather than straight in out motion, that sets up a pressure wave in the inlet manifold that pushes the air flow meter back causing fuel starvation.
Other things possibly to look at are fuel pump for quantity delivery not just pressure, blocked fuel filters restricted pipes.
If it is pre 1988 check the control unit for dry solder joints on the transistors they can be problematic causing rough running & non start.
Edit to add; I had a 530D at work with cutting out at high rpm, no faults stored, we found a plastic bag in the intake that was blocking up the air flow in at high rpm
blood69
Sat Mar 21, 2026 12:58 am
UPDATE.
Guys, finally after all this time I got it.
The hose of the fuel pump, the one inside the fuel tank was bad. I would never thought that it could cause backfire and rpm drops the way it was happening.
I also found out that the AFM and ICV is also bad, but after sorting out the fuel pump, if I disconect the AFM and iCV the car runs great and revs all the way to the rev limiter.
Tomorrow I'm gonna do some testing but finally some breakthrough on the issue.
I'm guessing this was a mix of issues, but the stupid thing was I never saw the fuel pressure being dropped when the issue happen.
Maybe the analog dial was not fast enough for me to see it.
The thing is after sorting the fuel pump issue the dial jumped to 4 bar, it was adjusted to 3bar previously, so it was loosing pressure because it risen 1bar after the fix.
I've adjusted again to 3 bar on the FPR and lets see Tomorrow how it's gonna behave.
The wire on the ICV connector is bad so I'm gonna redo it. Also I'm gonna check the wiring on the AFM but I'm pretty sure the AFM is at fault, it doesn't give me more than 3.8 volts, it should hit 4.5v fully open.
Thanks a lot for all your help.
Sat Mar 21, 2026 1:33 pm
Glad you got it all sorted mate
:clap: :clap: :clap: :clap: :clap: :clap: :clap:
Sat Mar 21, 2026 11:49 pm
Yes, well done. Strange how it revs up fine with the AFM disconnected though!
blood69
Mon Mar 23, 2026 6:25 pm
Yeah, I was amazed how the car runs without knowing the engine Load. I guess the guys at bosch were not folling around.
Try on yours. Disconnect ICV and the AFM, it should hold idle with the ICV Disconected. Mine does.
At very light throttle the car jerks a little bit. But half throttle and WOT it works fine.
The ecu goes to limp mode and applies Alfa N strategy using the RPM and part and full throttle from the TPS.
Probably it uses more fuel and retards the timing but the engine runs fairly well given the circumstances.
Mon Mar 23, 2026 10:08 pm
Yes, it's probably just running off the default or last remembered map with the AFM disconnected. Probably OK short term, but ideally, you need the AFM to enable the ECU to gauge the airflow and thus correct fuelling.
blood69
Tue Mar 24, 2026 1:10 am
Yeah, I just bought this one
https://www.ebay.com/itm/256452953699
Should arrive next week
