Lsd options
rix313
- Contact:
188 spools were in E34 and E36s. These fit inside E30 188 cases but need to be fitted and shimmed correctly by a specialist. You can look at something like a geared unit like a Blackline. Cost effective and low maintenance so good for a road car. This will still need the same shimming and set up as fitting an OEM plated spool. LSDs are not a cheap game.
