Lsd options
Corasdad
Sat Dec 13, 2025 8:17 pm
I have swapped in an m52 and i am thinking it might need an lsd what options do i have other than an e30 lsd which seem to be like rocking horse poo
rix313
Fri Dec 26, 2025 6:04 pm
188 spools were in E34 and E36s. These fit inside E30 188 cases but need to be fitted and shimmed correctly by a specialist. You can look at something like a geared unit like a Blackline. Cost effective and low maintenance so good for a road car. This will still need the same shimming and set up as fitting an OEM plated spool. LSDs are not a cheap game.
Corasdad
Sat Dec 27, 2025 10:22 am
Do you shim them or just supply the lsd unit
