Rear diff options
Corasdad
Whats the best rear diff for m52b28tu swap mine has a 1.8 auto diff in and it feel ok but is there a better option for normal spirted driving
There are a number of LSDs with differing gear ratios - try and work out what's best for your needs (based on whether or not you do a lot of motorway driving, etc.) from this list:
https://www.e30zone.net/e30wiki/index.p ... fferential
The lower the number, the higher the overall gearing will be. For most general purpose use, the Sport's 3.91:1 will be about right.
flybynite
Thing I would be most concerned about is what size is the existing diff. Small case diff wont last long behind an M52 Go for a medium case and as above something in the region of 3.25-3.95 depending on gear ratios.
There are some good web sites to calculate this, depending on what you need/want
Corasdad
How doni know if my diff is small or medium, i cant afford an lsd at the moment but its on my list with rear disc conversion
flybynite
Its all in the wiki
But if that is too much to read just count the bolts on the rear case 6bolts=small case, 8 bolts=medium case
