Z3 steering rack advice
Corasdad
Post Mon Apr 15, 2024 7:56 pm
I want to add a z3 steering rack, I understand I need one from the 1.9 model for the 2.7 turn option, can I use standard inner and outer tie rods from the e30 as I want to keep my wheels which are 4x100
flybynite
Post Mon Apr 15, 2024 8:34 pm
Corasdad wrote: โ†‘
Steering rack won't make any difference to the wheel fitment, it all uses the same hubs. This should answer everything :thumb:
https://www.e30zone.net/e30wiki/index.p ... onversions
Corasdad
Post Tue Apr 16, 2024 8:45 am
Thank you as always ๐Ÿ‘, it says I don't need a custom steering linkage is this correct for m52 swaps
flybynite
Post Tue Apr 16, 2024 11:35 am
The Z3 rack does not need the custom linkage as it is the same as the E30 rack, it is the E46 purple tag rack that need a different linkage.
The only issue is that the M5X engines tilt further toward the exhaust/steering side and it can be very tight for the exhaust compared to the M20. The thinner linkage gives more space for the exhaust.
fixedwheelnut
Post Tue Apr 16, 2024 2:59 pm
any queries contact @DanThe at BM Conversions on Facebook, he supplies all the necessary pipe work and steering couplings you need depending on the rack and engine fitted, excellent quality
https://www.facebook.com/search/top?q=b ... 20uk%20ltd
