Got some now do I use my red llctite and put them in or what?
Have the original ones in there but they seemed so loose as I was changing the hoses I thought ide change them, do I loctite the new ones in to hold them still while I do the throttle body up or some other way.
Manifold/throttle body studs
Armanib666
Well if you don't loctite them, they'll just unscrew as you do the nuts up. Or we're my studs shrunk or the manifold got that much bigger
How hot does the throttle body area get?
I would copper grease as you never know when you have to remove them again, old cars now you know
Lock two nuts on one end and tighten the studs into where they should be .
These wont move or undo when tightening up the nuts.
Armanib666
There too short they'd screw pretty much all the way in until there's no thread left, so I can't, that's why I'm using thread locker
Armanib666
These are the studs. They have tj go through the throttle body into the heater plate then into the manifold
There's not much thread to work with
- Attachments
Armanib666
Think if found my problem. That blue loctite doesn't actually work(cheap unknown brand)
Tomorrow if it doesn't rain I'll REAL loctite them in place with my new bolts.
And the problem will be sorted alongside my new throttle cable. Maybe a fresh magic tree too.
- Blanca
- Contact:
I have found that if studs are loose in alloy then it will not long before they wear the threads and work loose. best to bite the bullet, remove the throttle body and fit some inserts and fix it once and for all. Go for nutserts rather than helicoils,
All comments by me should be taken in the right sprite, Jack Daniels is fine.
