Manifold/throttle body studs
Armanib666
Post Sat Dec 18, 2021 10:01 pm
Got some now do I use my red llctite and put them in or what?
Have the original ones in there but they seemed so loose as I was changing the hoses I thought ide change them, do I loctite the new ones in to hold them still while I do the throttle body up or some other way.
rix313
Post Sun Dec 19, 2021 9:23 am
Red is a bit much. If you do use loctite a tiny dab of 243 'blue' at the most. I never thread lock parts into engines personally.
Armanib666
Post Sun Dec 19, 2021 2:12 pm
Well if you don't loctite them, they'll just unscrew as you do the nuts up. Or we're my studs shrunk or the manifold got that much bigger
How hot does the throttle body area get?
Post Sun Dec 19, 2021 2:32 pm
I would copper grease as you never know when you have to remove them again, old cars now you know winkeye
Lock two nuts on one end and tighten the studs into where they should be .
These wont move or undo when tightening up the nuts.
Armanib666
Post Sun Dec 19, 2021 3:18 pm
There too short they'd screw pretty much all the way in until there's no thread left, so I can't, that's why I'm using thread locker
Armanib666
Post Mon Dec 20, 2021 7:26 pm
These are the studs. They have tj go through the throttle body into the heater plate then into the manifold
There's not much thread to work with
Post Wed Dec 22, 2021 5:23 pm
Get yourself some threaded bar from e-bay and cut it longer and then you will have what you require :D :D
Armanib666
Post Fri Dec 24, 2021 10:07 pm
Think if found my problem. That blue loctite doesn't actually work(cheap unknown brand)
Tomorrow if it doesn't rain I'll REAL loctite them in place with my new bolts.
And the problem will be sorted alongside my new throttle cable. Maybe a fresh magic tree too.
Post Sat Dec 25, 2021 12:16 pm
8O 8O 8O 8O
Blanca
Post Sat Dec 25, 2021 1:45 pm
I have found that if studs are loose in alloy then it will not long before they wear the threads and work loose. best to bite the bullet, remove the throttle body and fit some inserts and fix it once and for all. Go for nutserts rather than helicoils,
All comments by me should be taken in the right sprite, Jack Daniels is fine.
