I know it`s not OEM but I wont tell if you wont
Cheers Mart.
Cheer mate, I`ll have a look at thisCloggy Saint wrote: ↑Sun Aug 29, 2021 3:37 pmThe oem item is a horseshoe shaped frame with a cradle at the front to hold the extinguisher. The whole assembly then bolts to the underside of the seat using the pre-existing holes. Remove one of the seats and it all becomes fairly obvious.
Here you go
He has an extinguisher already, Mart is only looking for a picture of the bracket. It is simple enough design and I'm sure he can knock one up at work for a couple of quid
It's the original bracket that's expensive, with the retaining clip etcflybynite wrote: ↑Sun Aug 29, 2021 7:59 pmHe has an extinguisher already, Mart is only looking for a picture of the bracket. It is simple enough design and I'm sure he can knock one up at work for a couple of quid
New the extinguishers are only about £60 or much less if you don't mind not having the BMW logo![]()
Agreed, if you want an original, in good condition (possibly even working) then yes they are expensive. There is one in fair condition on ebay now for £170 so they do come up.
Correct. You still need the extinguisher bracket - which BMW still sells new alongside with the extinguisher.Cloggy Saint wrote: ↑Mon Aug 30, 2021 10:51 amThat ebay bracket isn't much use without the cradle to hold the extinguisher, or am I missing something?
Yes you areCloggy Saint wrote: ↑Mon Aug 30, 2021 10:51 amThat ebay bracket isn't much use without the cradle to hold the extinguisher, or am I missing something?
Nice one. Definitely ordering one. New eBay listing at https://www.ebay.co.uk/itm/Fire-extingu ... 5044297603flybynite wrote: ↑Mon Aug 30, 2021 8:46 amAgreed, if you want an original, in good condition (possibly even working) then yes they are expensive. There is one in fair condition on ebay now for £170 so they do come up.
But every new 1kg or 2kg extinguisher will come with a mounting bracket. A brand new 'Gloria' extinguisher (which BMW use) will come with a mounting and retaining clip. It is different to the old one being a simple mount and plastic retaining strap but works and can be bolted to the metalwork like the old full 'cradle' mount.
For anyone who is adept at metalwork, the seat mounting bracket would not be a difficult exercise.
Now and again someone makes a batch and sells them on ebay, like this guy. (although he has run out for the moment) but you could probably get one knocked up for half of that.
https://www.ebay.co.uk/itm/164272327583
£45 for one of those and about £37 for one of these
https://www.safelincs.co.uk/2kg-powder- ... oria-p2gm/
Would give you a proper 2kg brand new extinguisher that works, mounted correctly for about £80
I would still carry a firestick in the glovebox
So the Gloria is a straight fit into the eBay bracket linked above?flybynite wrote: ↑Mon Aug 30, 2021 12:19 pmYes you areCloggy Saint wrote: ↑Mon Aug 30, 2021 10:51 amThat ebay bracket isn't much use without the cradle to hold the extinguisher, or am I missing something?![]()
As I said above in the post a new extinguisher, either aftermarket or a new one from BMW will come with a bracket to hold the extinguisher. Extinguishers are not the same shape so each one has a bespoke bracket for it.
The 'Gloria' 2kg one I linked to above even has captive nut keeps in the plastic to bolt them to the ironwork. I have one fitted in all my cars.
No-one makes a cradle-like bracket any more and if you have one it will only fit the '80s or '90s extinguisher it was made for
You are probably going to drill mounting holes as all the extinguishers have different mounting holes. My extinguishers bought 5 years ago have different holes to the one I bought last year. 2kg extinguishers are different to the usual BMW ones as they are only 1kg (BMW did do 2kg extinguishers as I have one) More chance of actually doing something with 2kg.
I’ve ordered https://www.ebay.co.uk/itm/164272327583 as someone recommended it. Only realised that it’s LHD after ordering and seller didn’t respond so I’ll end up with fitting it on the front left seat I guess.steve_k wrote: ↑Thu Sep 09, 2021 8:59 ammart seeing as you are a tool maker i'm sure you would be able to drill new holes in the bracket if needed,
there's also this bracket which i'll be ordering myself in the next week or so,
https://www.tegiwaeuro.com/kap-industri ... -94-m.html
but if you look the holes are elongated so might not need altering to fit.
well for £30 what have you lost?twenty wrote: ↑Thu Sep 09, 2021 9:10 amI’ve ordered https://www.ebay.co.uk/itm/164272327583 as someone recommended it. Only realised that it’s LHD after ordering and seller didn’t respond so I’ll end up with fitting it on the front left seat I guess.steve_k wrote: ↑Thu Sep 09, 2021 8:59 ammart seeing as you are a tool maker i'm sure you would be able to drill new holes in the bracket if needed,
Indeed. Just surfacing this in case someone else is more picky than I am. I’m happy to have the extinguisher in the left seat and even prefer it.steve_k wrote: ↑Thu Sep 09, 2021 9:25 amwell for £30 what have you lost?twenty wrote: ↑Thu Sep 09, 2021 9:10 amI’ve ordered https://www.ebay.co.uk/itm/164272327583 as someone recommended it. Only realised that it’s LHD after ordering and seller didn’t respond so I’ll end up with fitting it on the front left seat I guess.steve_k wrote: ↑Thu Sep 09, 2021 8:59 ammart seeing as you are a tool maker i'm sure you would be able to drill new holes in the bracket if needed,
The seats are both the same, why would it fit on the left and not the right?twenty wrote: ↑Thu Sep 09, 2021 9:10 amI’ve ordered https://www.ebay.co.uk/itm/164272327583 as someone recommended it. Only realised that it’s LHD after ordering and seller didn’t respond so I’ll end up with fitting it on the front left seat I guess.
My mistake only noticed that myself, there was someone a while back selling ones that were RHD and I thought it was the same guy. 2 mins with a grinder and mig and it is reversed.twenty wrote: ↑Thu Sep 09, 2021 9:10 amI’ve ordered https://www.ebay.co.uk/itm/164272327583 as someone recommended it. Only realised that it’s LHD after ordering and seller didn’t respond so I’ll end up with fitting it on the front left seat I guess.
Small matter of the slide adjust handle that gets in the way. The bracket, including the OEM ones are slewed to one side.Cloggy Saint wrote: ↑Thu Sep 09, 2021 5:10 pmThe seats are both the same, why would it fit on the left and not the right?![]()
That’s encouraging. Let’s see when it arrives.Cloggy Saint wrote: ↑Thu Sep 09, 2021 10:48 pmI used to have an oem extinguisher and bracket and I had it on both seats no problem.
It wouldn't let me attach a video so here's some screenshots from video. The new one does come with its own strap on it and a small back plate that fits onto the metal bracket however doesn't fit into the nice sturdy OEM holder.
But you are taking the new extinguisher out of its new holder and trying to push it into the one for the old extinguisher. Each extinguisher comes with a holder and you bolt that to the bracket.
