Hi, I removed my 1987 325i Sport throttle body and measured it. It's 63.5mm. Is that bigger than standard?
I've seen a big bore version on eBay, its diameter is stated as 64mm?
Std 325i preface throttle body size?
flybynite
You had the right answer on faceacheM3kuksport wrote: ↑Sun Nov 22, 2020 6:42 pmHi, I removed my 1987 325i Sport throttle body and measured it. It's 63.5mm. Is that bigger than standard?
reggid
they are 60mm @ the butterfly noting that it is tapered meaning the entry is larger like 63mm or thereabouts
E30 325is with M20B31
