Std 325i preface throttle body size?
M3kuksport
Post Sun Nov 22, 2020 6:42 pm
Hi, I removed my 1987 325i Sport throttle body and measured it. It's 63.5mm. Is that bigger than standard?
I've seen a big bore version on eBay, its diameter is stated as 64mm?
flybynite
Post Sun Nov 22, 2020 7:26 pm
M3kuksport wrote: ↑
You had the right answer on faceache :D
reggid
Post Sun Nov 29, 2020 9:38 pm
they are 60mm @ the butterfly noting that it is tapered meaning the entry is larger like 63mm or thereabouts
E30 325is with M20B31
