Consolidated E30 Dismantling Thread - 316i to 325i Sport & M3...
Bally325
Hi I’m after a flywheel for a j reg bmw325 auto delivered to Sl3 thanks
Vez010
Do you have a heated seat kit for a retrofit?
AshE30M40
Hi do you have a powersteering pump and pulley for a 1990 316i m40?
choppa7
Do you have any double fog light switches available?
1990 318i Lux
twenty
Have you got a Z3 steering rack please?
vonmarshall
Hello
Do you have a rear LH light for 1984-1990 E30? Part # 63211368823. One that looks like this...
joeyb
Hi, have you by chance got any brake pedal return springs knocking around? My brake pedal doesnt fully return quite often meaning the brake lights stick on. I've seen on RealOEM there is a spring installed on some E30s... mine has the slots but no spring present.
Joe
Joe
Elkcarc
Do you ever have rear quarters/inner arches either side for a 1989 325i. Happy to pick up or pay postage.
stmachreth
Hi, do you have rear left and right bumper brackets?
41351971597 and 41351971598
Acaciastrain360
I need a pair of rear bumper shock absorbers please
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Acaciastrain360
323i Clutch release bearing ?
sskoda
Nope. Best getting new if you can anyway.
E30Loading
Any LSD available?
sskoda
Should have one 3,91 available from next week.
Fantombiker
Hi, looking for a fuel sender for a 1994 touring drivers side....do you have one
yukinotomo
I'm looking for a clutch pedal and a brake pedal for RHD E30.I'm not looking anywhere, so please.From Japan.
onthames
Can you send a photo of which parts you need as pedal could mean the whole system or just the rubber bit on the end.yukinotomo wrote: ↑Fri Aug 27, 2021 12:52 amI'm looking for a clutch pedal and a brake pedal for RHD E30.I'm not looking anywhere, so please.From Japan.
yukinotomo
Thank you for your quick reply comment.
What I want is the red circle part of the attached file.
Parts No:3531 1152 805 clutch pedal
3521 1157 852 brake pedal
sskoda
Hi. Is your car / your pedal box from a pre- or post- facelift car?yukinotomo wrote: ↑Fri Aug 27, 2021 12:52 amI'm looking for a clutch pedal and a brake pedal for RHD E30.I'm not looking anywhere, so please.From Japan.
sskoda
I don't want this thread to disappear forever, and it's been 6 months in situ. So later I'll add a picture of an E30 we're working on.
It's being picked up from paint tonight.
V8turd
Pm sent
Wingzero
Anybody have a 325i driveshaft? I was doing a rear disc conversion and for some reason one of my old driveshafts wouldn't go in the hub, so i swapped it for the one driveshaft that came with my rear disc trailing arms but of course, now it's thicker than the other one.
V8turd
Sent PM regarding a body cut (passenger side boot lip)
MikeBM299
Looking for the boot floor spacer to fit 15" spare wheel like in the picture attached.
TomBarnes95
Looking for some 15 Inch BBS alloys (4x100 ET24). Drop me a message if you have any available.
sskoda
Yes we've got a few sets available.TomBarnes95 wrote: ↑Thu Jun 09, 2022 3:14 pmLooking for some 15 Inch BBS alloys (4x100 ET24). Drop me a message if you have any available.
Liquid790
Hi.
I'm looking a pair of sunroof cables with the sliders on the end.
For a manual sunroof.
Thanks, Dan.
Thanks, Dan.
