Centre console removal
oguz327
Captain Armco
Captain Armco
Post Wed Feb 15, 2006 6:01 pm
I am in the process of removing my carpet, i have taken interior seats front and rear compleatly out now.
Next as far as i know i need to remove my centre console, and accelerator pedal.
Can anyone tell me where the fixings for the centre console are and how to remove accelerator with out breaking the fixing?
Also anyone with any diagrams or pics or just general advise with this would be most welcome.
cheers
dazleeds
old skool raver
old skool raver
Post Wed Feb 15, 2006 6:07 pm
centre console rear piece has a ten mm plastic nut under the rear ashtray
and the front part remove gear gaitor and theres a 10 plasi nut again near the gearstick apperture
there is also a plasi screw in drivers footwell next to clutch pedal
once them 3 are out just pull gently and slip console over the gearstick
not sure bout acc pedal sorry
hth
Daz
www.oldskoolfantasy.co.uk
eko
Old timer
Post Wed Feb 15, 2006 6:08 pm
Accelerator pedal is easy,remove the circlip at the top,pull it sideways of the linkage rod and pull it out of the floor!
It will be tight but force it to either side and it will come out.
If it breaks i got one here you can have but they are only cheap to buy new.
Centre console.
10mm nut under rear ashtray,another under the gear gaitor.
Back part will just lift out over the handbrake.Front part,there is a little bolt/screw(8mm i think)hidden.It is under the heater control part of the dash,a bit fiddly but not to bad.
Also down the sides of the console towards the front of the car,there should be two plastic twist screw things,remove these and i think thats it!
dazleeds
old skool raver
old skool raver
Post Wed Feb 15, 2006 6:10 pm
good thinking forgot about the wee screw into the dash :mad:
still beat ya too it tho :snigger:
eko
Old timer
Post Wed Feb 15, 2006 6:14 pm
:roll:
oguz327
Captain Armco
Captain Armco
Post Wed Feb 15, 2006 6:16 pm
many thanks guys, all ive got is an e21 hannes with e30 updates in, but it might aswell be in japanese lol
will give it a go tomorow, gonna run the car with no carpet for a while to see where water is comming, am i right in thinkin i can put center console back in even with no carpet in place?
Thanks again fellas
dazleeds
old skool raver
old skool raver
Post Wed Feb 15, 2006 6:17 pm
yeah console will go in without carpet
but may be a bit loose and rattly
Daz
:tongue: @ eko :lol: :lol:
eko
Old timer
Yes!
dazleeds
old skool raver
old skool raver
Post Wed Feb 15, 2006 6:19 pm
lol and again
eko
come on old fella :D
oguz327
Captain Armco
Captain Armco
cool Daz i can live with that 8)
is the carpet gonna be a bastard to put back in?
mabie need 2 people to do it?
dazleeds
old skool raver
old skool raver
Post Wed Feb 15, 2006 6:20 pm
can be a pain at the bulkhead/ heaterbox area if i remember right
and be very gentle with it when pulling out as they can rip veryvery easily
just take ya time with it youll be fine mate
Daz
EKO where are ya mate?? winkeye
oguz327
Captain Armco
Captain Armco
Post Wed Feb 15, 2006 6:32 pm
Cheers Daz and Eko lol you boys are fast.
Ill give it ago tomorow and fingers crossed not too much rust, so far passenger side is looking good.
Many thanks guys, ill post up tomorow let ya know how i got on
eko
Old timer
Post Wed Feb 15, 2006 6:51 pm
I give up :)
Post Wed Feb 15, 2006 10:36 pm
Accelerator pedal is not meant to be reuseable once its been removed, but in practice they usually come out OK. Only ever broke one that I can remember.
The carpet will be very tight under the heater, and its easiest if you cut around this piece with a sharp craft knife, leaving the piece under the heater in place. The cut will be completely covered by the front console.
MIND THE WIRES UNDER THE CARPET.
