hairline cracked sump.
steve_k
Post Thu Aug 13, 2020 12:52 pm
well after the past few weeks of trying to work out why the oil was leaking from the rear of the sump on my b27 it looks like i may have found the reason.
in the past few weeks i have had the sump off several times, replaced the gasket with a brand new one, even used some RTV sealant on it but still a drip when the front of the car is in the air,
well today while i was searching after replacing the gasket & keeping it in place with a dab of RTV i went round the back of it with some cheap degreaser (from the kitchen) & what do i find??
a hairline crack/split on the lowest point at the rear on the drivers side next to the bolt on the corner (about 5mm in between the 2 bolts).
so, looks like it's sump off (AGAIN!!!) & either get it ally welded & gummed up with plenty of JB weld.
why is it always the last place you look & never where you expect it??
flybynite
Post Thu Aug 13, 2020 5:08 pm
Bugger :cens:
Always the way
steve_k
Post Thu Aug 13, 2020 5:51 pm
Bugger :cens:
Always the way
tell me about it, fuming is an understatement :cens:
well i've cleaned it up as best i can, going to let it dry for a day then scuff it up with some 100grit sandpaper, degrease it again then break out the JB weld.
flybynite
Post Thu Aug 13, 2020 6:03 pm
Got anyone local that could v out the crack and TIG it? While sump is off would only be a 5min job
steve_k
Post Thu Aug 13, 2020 6:31 pm
there's no one i know of round here who could TIG it for me,
i'll try the JB weld for the time being while i either find a new sump or someone who can TIG it up for me.
just a bit :cens: because of it.
Post Fri Aug 14, 2020 12:00 pm
Whats JB welding ?
steve_k
Post Fri Aug 14, 2020 12:01 pm
Whats JB welding ?
Its a metal putty, used it a few times over the years,
Post Fri Aug 14, 2020 12:17 pm
Is it suitable for more than just one material ?
steve_k
Post Fri Aug 14, 2020 12:52 pm
It can be used on various substrate,
I've only used it a handful of time over the years so not much experience with it.
Cloggy Saint
Post Fri Aug 14, 2020 1:26 pm
Quicksilver is another option that I've had success with over the years.
steve_k
Post Fri Aug 14, 2020 5:44 pm
i'll have a look for that one, see if the local motor factors has got any in.
steve_k
Post Sat Aug 15, 2020 12:40 pm
well i made a start on the in situ repair to the crack.
drilled a small hole in the end of it to stop it going any further.
degreased the area thoroughly,
keyed it up with 100 grit sand paper,
used a very small amount of milliput to fill the crack then added a layer of JB weld,
going to eave it to set/cure then smooth it over & add another layer if needed, then leave it 48hr's before i refill with oil to see if it's worked.
only problem i ran into was finding out the gearbox mounts were FUBAR'd, good job i had some bolt through poly one's in the shed.
so they got changed while i was under there.
all in all not bad for a couple of hours work.
paultv
Post Sat Aug 15, 2020 4:42 pm
I've used Super Steel - I think Plastic Padding make it...get it from Halfords....had an annoying leak in the radiator where the drain plug fits...sealed it with SS about 3 years ago....solid.
I saw a clip on the tube where some geezer welded a diff with it...lasted about 10 minutes!!
Paul :-)
steve_k
Post Sat Aug 15, 2020 4:49 pm
Paul :-)
I know the stuff you mean but couldn't find any.
Welded a diff with it? 😳
Well if all else fails I've got some belzona 1511 ill use instead,
Alit qint cheap so I'm leaving that as a "just in case" measure.
If all else fails, new sump.
steve_k
Post Tue Aug 18, 2020 11:52 am
well just been out to check on the milliput in the crack & that had cured nicely,
sanded it back so it's all level, keyed it with some 80 grit,
mixed up the JB weld & set to covering the milliput with it making sure to give it a good even coat,
just got to wait 24hr's now for it to fully cure & uf need be i might give it a 2nd coat just to be sure,
hopefully by the weekend i'll be putting the oil back in & fingers crossed there's no more drip.
